Question about Sierra Entertainment Aliens vs. Predator: Requiem for PSP
The password or the encrypted file of aliens vs predator
I need the password for the encrypted file
Posted by bjaouiahmed on
  • Raghu Varan
    Raghu Varan Apr 02, 2017
    alien vs predator password pls
  • Janitha Sudharaka
    Janitha Sudharaka Aug 16, 2017
zakriya
    New Friend:
  • 3 Answers
Wat is the password of alien vs predator
Posted on Dec 07, 2013
Need password for encrypted file
Ask the one who did the encryption, because that is the only reason it was encrypted with a password, so nobody else could open it without his / her permission.
Mar 27, 2015 | Computers & Internet
Tip
PDF encryption, set PDF password and recover PDF password
PDF encryptionGenerally, PDF files are with a password called User Password, which is used to open the file and view the document. To encrypt a PDF password does not simply mean you can’t open and view the document, but PDF files have five to seven encryption ways to protect the file for office needs. Owner password, the other password of PDF files, is another crucial PDF password, which is to protect the file from maybe being copied (to Clipboard), printed, or modified, etc. So, in speaking of PDF password, it doesn’t necessary mean the one which you use to open the file.
PDF encryption largely relies on the sophisticated algorithm that hardly to be reversed. For example, you are easy to calculate that 1000 plus 1 is 1001, however, the reverse is seemed impossible, for 1001 can be an answer of countless calculations. PDF encryption works in the similar way. In this sense, given a password, it’s easy to deduce and decipher some data; however, the reverse PDF password recovery seems impossible.
Generally speaking PDF encryption with 128 bits key value is much more secure than that of 32 bits. PDF encryption is accomplished by a key value, either 128 or 32 bits in size. When using the key, all the bytes are changed (unless they are decoded back with the same key) into meaningless codes, and the file is impossible to be opened. Only the meaningless codes are calculated back using the correct value is it possible to get the correct password and open the file. 128 bits has a lot more possible values than the one with 32 bits, so it is much more secure. If your password is forgotten and intend to recover PDF password, PDF Password Unlocker software could be faster, for it supports 128 bits encryption, either 128 bits RC4 or 128 bits AES encryption.
PDF files are composed with objects, like image Objects, graphic Objects, and text Objects, etc. The key is calculated for each PDF Object in the PDF file using local data, which is much hard to crack, as the key keeps changing.
Set and remove PDF passwordsAdd a PDF Password1. Click the Secure button pdf-encryption-and-pdf-password-recovery_clip_image002.jpg in the Tasks toolbar, and choose Password Encrypt.
2. Click “Yes” to the prompt about changing the security, and if necessary, type the Permissions password that lets you change security settings. If you don’t know the password, contact the author of the PDF.
3. In the Password Security - Settings dialog box, set the security options as desired, confirm the password, click OK, and then click OK again.
4. Save the document to apply the security settings.
Note: You can also restrict editing capabilities when you certify a document, or when you apply a policy to a PDF.
Remove PDF passwords and security settingsYou can remove PDF passwords and security policies from an open PDF if you have the permissions to do so. If the PDF is secured with a security policy that resides on a server, the changes can be made only by the author of the policy or by a server administrator.
1. Do one of the following: Click the Secure button pdf-encryption-and-pdf-password-recovery_clip_image002_0000.jpg in the Tasks toolbar, and choose Remove Security.
Type your password, and click Yes to the prompt about removing the security.
In the Security tab of the Document Properties dialog box, choose No Security from the Security Method menu.
2. When prompted, specify the Permissions password, and then click OK. Recover PDF password in case you forgot it.Every coin has two sides. Even the PDF document is strongly encrypted with passwords, it is impossible to insure that it is secure. Once you forgot PDF password, the data in the encrypted PDF file are on the risk of unavailability. Unless fortunately the password knocks your memory again, you got the data lost or you have to give up the document eventually. With the ever-growing of strong encryption algorithms, decryption algorithms gradually come into existing, too. Though the cracking is far more difficulty than ever before, it is still of help to those expecting to recover PDF password and access the password protected PDF file. Take PDF Password Unlocker, a popular PDF password recovery software, for example, it has adopted the advanced decryption algorithms to crack 40-bit RC4, 128-bit RC4, 128-bit AES, and 256-bit AES encrypted passwords with 3 attack methods, Dictionary attack, Brute-force attack, and Brute-force with Mask attack
Reference: http://www.passwordunlocker.com/knowledge/pdf-encryption-and-pdf-password-recovery.html
on Apr 30, 2010 | Computers & Internet
I need extract password for CSI Hard Evidence
It sounds like the zip file you're trying to access is an encrypted zip archive. So to correctly open the zip file, you need to identify what exactly it was encrypted with and I should be able to help!
Feb 27, 2015 | Computers & Internet
Password for encrypted file
We are dedicated to the work on professional RAR Password Recoverysoftware that helps you find passwords of encrypted WinRAR files.
Apr 16, 2014 | Electronic Arts The Godfather II
Encrypted files password
password of encrypted file of transformers the game
Jul 18, 2013 | Activision Transformers The Game for...
Requard floder password
. Install VeryAndroid File Protector on your Android phone.
Go to the Market (on your Android) and search for VeryAndroid File Protector. Download and install it on your phone directly.).
2.
Run the VeryAndroid File Protector on your phone and you will see this screen:nlpvlrzmaaaaaaaelftksuqmcc
3.
Here you can select the file/folder you want to encrypt and protect. Click the file or long click the folder and you will see this screen:
4.
Click Encrypt File, enter your password then click "Encrypt" to continue:
5.
Done. Now the file/folder have been encrypted and locked.
Nobody will be able to access these protected contents without your password.
Feb 14, 2012 | Samsung S5620 Cell Phone
Dear all, I have encrypted a file and will open it later on. I type in the password and checkboxes "Open file after decryption" and "Encrypt file after use". Then the file opens but the...
It may be encrypted with windows encryption, but in your table of "Registered File Types"
you have Kruptos 2 Professional as the program to open, based upon the file type.
Also, if the file is one of the versions of Microsoft Word files, it can have a decryption
password assigned through Microsoft Word, in addition to a separate password
from Windows encryption and/or Kruptos encryption (Yay! up to 3 passwords to
decrypt/access one file!)
Either that, or the Kruptos 2 Professional software is buggy, and you've already discovered the workaround.
Check Kruptos for update(s) to its software - they may have fixed it in a bug-fix release (much
like Microsoft releases numerous updates, hot-fixes, and service packs for its bug-filled operating systems software suite, and Microsoft Office software suite).
http://www.kruptos.com is all in French.
Jul 08, 2011 | Kruptos2 Kruptos 2 Professional
I need the wwe smackdown vs raw 2011 password for encrypted file i downloded it from torrent
WHAT IS THE PASSWORD FOR THE ENCRYPTED FILE: SMACKDOWN VS RAW 2011 PC GAMES SETUP RAR
Mar 24, 2011 | Computers & Internet
Decrypting the encryption
what is it that is encrypted? more information is needed are you refering to the encryption file and the password list or do you have an encrypted hard drive? or an encrypted .rar file ultimatly you have to figure out the encryption key then revers it onto the target that is encrypted best of luck the all knowing ****
Feb 24, 2010 | Dell Inspiron 530 -Intel® Pentium®...
How do I encrypt an individual computer file?
Hi brianeckhear
  1. Click Start, point to All Programs, point to Accessories, and then click Windows Explorer.
  2. Locate the file that you want, right-click the file, and then click Properties.
  3. On the General tab, click Advanced.
  4. Under Compress or Encrypt attributes, select the Encrypt contents to secure data check box, and then click OK.
  5. Click OK. If the file is located in an unencrypted folder, you receive an Encryption Warning dialog box. Use one of the following steps:
    • If you want to encrypt only the file, click Encrypt the file only, and then click OK.
    • If you want to encrypt the file and the folder in which it is located, click Encrypt the file and the parent folder, and then click OK.
Note that if you allow other users access to an encrypted folder and they put an encrypted file in it then they would need to grant you access to file before you can open it.
Also encrypted files cannot be stored on remote servers unless it's configured as Trusted for delegation. To do that you would need admin access to the domain controller
More info can be found here
I'm not 100% certain but I don't think encryption capabilities are built into Windows Home editions. You could compress the file in this case and password protect it.
May 11, 2009 | Computers & Internet
Sierra Entertainment Aliens vs. Predator: Requiem for PSP Logo
2,122 people viewed this question
Top Sierra Entertainment Video Game Consoles & Games Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Tom Chichester
Are you a Sierra Entertainment Video Game Console and Game Expert? Answer questions, earn points and help others
