Not sure of your particular MB, but most always the switch is a pair of pins in an array where the front panel LEDs and reset and power switch are.
This array of pins is almost always at the lower right hand side of MB. Assume the components side is facing you and the expansion slots are at your left hand, (where you add extra cards like video etc). then look at the lower right side or bottom edge, mostly right at the edge of the board. Should be an a double row of pins, at least 8 maybe up to 12. Look real close next to these and you may see print indicating which pair do what. PS = power switch. RS = reset, HD = Hard drive LED PLED = power led light.Spk internal beep speaker etc. (Note LEDs require correct polarity to work) Sometimes no print there.. Then you need the manual to decipher pin pairs. Or experiment. All you need to do is make the connection momentarily (like push button) with a small screw driver tip to start it, while looking for correct pins.
If no power on check your power supply connections on the MB. Or suspect either MB or Power supply issue.
