Question about NetGear WG602 802.11g/b Wireless Access Point
Netgear access point cant open 192.168.0.227 - NetGear WG602 802.11g/b Wireless Access Point
1 Related Answer
Anonymous
  • 1049 Answers
SOURCE: Netgear access point cant open configuration page
Typically you should be using configuration software until a real IP can be setup and you either address it statically or turn on DHCP. As for the gateway and other information, on a wireless gateway, it should all be routed through the network. Also, I think you have to be wired to the WAP to access the config page, I don't believe it can be seen over the wireless connection as a security feature.
Posted on Aug 02, 2010
NETGEAR AND UPNP
Yes your Router supports UpnP.
http://kbserver.netgear.com/pdf/wg602v3_manual.pdf
Here is the manual where I found the information. Once the manual is open ctrl+F will open a find window. In the find window enter UPnP and click enter on your keyboard. This will take you to the section explaining UPnp and how it works on your router.
Good Luck!!
Aug 13, 2012 | NetGear WG602 802.11g/b Wireless Access...
Can't open 192.168.0.227
To RESET the Netgear, power up the Netgear then press andhold the RESET button at the back of the router until all the LEDs flash.Connect a LAN cable from the Netgear to the LAN port on yourcomputer, open a browser and enter the Netgear configuration URL -
http://192.168.0.1
The default login = admin
The default PW = passwordYou can now change the default admin password and configurethe wireless settings.
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.
Apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Mar 25, 2012 | NetGear WG602 802.11g/b Wireless Access...
Can't configure netgear access point wg602
try to access the the router by using address 192.168.1.1, if this don't work then reset the router and used the factory setting in the manual
Can't access 192.168.0.227
This configuration IP address is wrong for the Netgear.
http://192.168.0.1
Aug 02, 2010 | NetGear WG602 54Mbps Wireless G Access...
My PSP internet connection not supported to my access point.
The SSID is the NAME of your Routers connection. So you need to know your WiFi connections Name, That's the "Access point" Security, Is IF you assigned a WEP/WAP KEY, when the router was first setup. If NO Key is set, that is what it means "Unsecured",
You need to get a Netgear router manual, for your exact model, it shows all in pictures how to do it.
Apr 25, 2010 | Sony PlayStation Portable (PSP) Slim...
I cant get to the gatway interface
It seems to be a hardware failure with the unit. Reset the AP using step below:
At the back of the router you will find a small tiny hole (which has a small button inside it). Press the button with the help of a paper clip. and hold it down for 30 seconds. After 30 seconds, please release the button and power off the device for 5 seconds.
Check if you are able to access its configuration page using the steps below:
1. Connect the computer to the access point.
2. Click start button (extreme bottom left corner of the screen) on the computer.
3. Click Control Panel from the list.
4. Click on Network Connections.
5. Right click on 'Local Area connection' icon and click on properties.
6. Select Internet protocol TCP/IP from the list of components and click on properties.
7. Select use the following ip address.
8. Assign ip address as: 192.168.0.90 ; subnet mask as: 255.255.255.0 and Default Gateway as: 192.168.0.227
9. Press 'OK' and 'close' the properties window.
Login to the access point page using the following steps:
1. Open a browser (Internet Explorer or Mozilla Firefox).
2. Access the router (usually http://192.168.0.227).
3. Login to the AP(User Name = admin and Password = password).
Rate it, if it helps.
Jun 24, 2009 | NetGear WG602 802.11g/b Wireless Access...
Cant connect to explore msn and email works but explore cant open a page
Disable your firewall on the computer and check if that helps.
If the issue persists then reset your browser to default settings and try again. You may also try instaling another browser like Mozilla to isolate issues with the browser.
Jun 20, 2009 | NetGear Super G Wireless Router
How to use wireless without beinbg plugged in to ether cable
Scan foir the wireless network on the laptop and connect to the network:
1. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
2. Right-click on the wireless Network Connection icon and select 'Properties'.
3. Click on the 'wireless network' tab.
4. Under Preferred networks if you see any name in the list then highlight the name and click remove.Click OK.
5. Right-click on the wireless Network Connection icon and select 'View Available Networks'.
6. Look for the SSID (aka Network Name) of the Wireless router or access point.
4. Highlight the SSID from the list that you want to connect to.
5. Type the security Key here and click on the 'Connect' button.
6. You should have successfully established a wireless network connect
May 17, 2009 | NetGear WG602 54Mbps Wireless G Access...
Sky netgear router
add your previus setting in your netgear router
fist you have contect with your pc and config and fist resert the all current seting
Mar 31, 2009 | NetGear RangeMax Dual-Band Wireless-N...
NetGear WG602 802.11g/b Wireless Access Point Logo
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Mike
efs_perpends
efs_perpends
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
