Question about Element Electronics Televison & Video
My element electronics tv says no signal
My element electronics tv that I got a couple months ago keeps saying no signal and the cable cord works on the other tvs how do I fix this please help
Posted by sara_lynn22 on
SD Tech
    Top Expert:
  • Element Elec... Master
  • 14,553 Answers
Two things to try:
1. Connect a DVD or something else to one of the rear audio/video inputs to see if set works that way.
2. Check to make sure set in menu is set to tuner and cable---if the tuner in the set is bad a cable box with audio/video outs on the back can be hooked to one of the rear audio/video inputs and will bypass the tv tuner--you will stay that input to watch TV and change channels with the box----
The cost of renting a box is minor compared to having to replace the tuner in the set.
Posted on Mar 24, 2012
5 Related Answers
Mark Egan
  • 1214 Answers
SOURCE: TV says no signal from direct tv box
Yes, something could have gotten changed.
Confirm what input connection the DirecTV receiver is connected to on the back of the TV. Using the remote, check that the TV has that input selected.
Posted on Dec 16, 2009
Anonymous
SOURCE: tv says no signal after hooking up computer to it
I had same problem, adjust settings on your computer desktop resolution to 800x600 solved my problem right away, computer resolution is probably too high. Hope this helps!
Posted on Jun 09, 2009
Anonymous
SOURCE: "weak signal" on my RCA scenium
Hey! I have the same problem as you. But! this would happen only when I got a power outage. Unplug the TV for a couple of minutesand all was fine. For the last 5 day I have no TV. I have tried everything. All the out on the TV and I still get unusable signal. My rep told me to unplug for 24 Hours. Still didn't work. My menu option work as well and every time I put the TV on, off or if I change the input sound will come on for 2 seconde and stop. If I find the salution I will let you know. Gilles Ottawa
Posted on Apr 12, 2007
Anonymous
  • 55 Answers
SOURCE: it says no signal when I turn it on, the wire will work the other tv
If it does this on your tv channels and channel rescan doesn't help, it is probably a bad tuner.
Posted on May 01, 2009
Richard Tirado
  • 73 Answers
SOURCE: Element tv.. model # ELCHS261 stopped working
Change the input. There should be an "input" or "source" button on the remote and/or tv for choosing the source for signal display. Change it to one of the other options (try all of them).
Posted on Jul 10, 2009
How do I fix my Element 55" LCD TV?
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Jan 23, 2015 | Element Televison & Video
BBC Iplayer App keeps hanging
It is probably a signal issue. Check by resetting your router.
Nov 24, 2017 | Samsung Computers & Internet
Cant find power cord for element flx 2610 would any other models from element tvs work?
As long as same pin out at end and same shape----all are usually the same but one side goes to hot and other to neutral side inside the set.
Nov 05, 2012 | Element Electronics Televison & Video
Hi we have lost all channels of our hisence tv just blue screen saying no signal please help had channels yesterday
Nothing to worry, You change to AV mode to TV mode and wise verse,
If nothing happen then call the service center, It only two months old.
Jul 23, 2012 | Hisense LCD1504 15 in. Television
Only getting blue screen on both tvs. one keeps saying no signal but have checked all cables but cant solve prblem. other tv says scan channels but i have scanned channels.
New TV's or new problem? If these are new TV's it could be that they are set on something other than the Cable Input Option.
On your remote press the input button to get an onscreen menu and set them to cable.
Otherwise, if you installed these yourself recently, recheck all connections to make sure they are set up correctly, using the manuals that came with the TVs. My guess is that you may have connected them incorrectly to/from the cable input device.
If these are not new TVs and this is a new problem, take a look at your outside cable box. Occasionally one can have a problem with an input cable. If that is the case, the cable company needs to be called to replace or repair.
Thank you for using FixYa.
Dec 26, 2010 | Element Electronics FLX2211B 22 in. LCD TV
Why is my element FLX-2210 saying so signal
It is saying no signal becuase it is not getting he signals from video source or from the cable. Try it on another cable location in the house, if still the same, then you have problem in the main board.
Please read my guide to understand how LCD TV works.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx
Aug 13, 2010 | Element Electronics FLX-2210 22 in. LCD...
My Guide Plus stopped working 2 months ago. Time
Also on Time Warner Cable and two TVs have stopped receiving Guide Plus in the last month.
Does anyone have suggestions?
Jun 09, 2010 | RCA F36650 36" TV
My gateway t-6330u hdmi cannot connect. It shows the the external monitor is connected but my TV set shows no signal. and it worked perfect couple month ago
Here is something you may or may not have tried:
With the HDMI cable hooked up to your TV set, reboot your computer. in many cases (even though it may be shown as hooked up) the video card will not send a signal on a specific output unless there is something plugged into it on bootup. Once that has been done, verify that you are on the proper HDMI setting on your TV. Many TVs have multiple HDMI inputs, so it is possible that there is a signal and it's not switched to it.
Sometimes its about going to the basics.
Nov 03, 2009 | Computers & Internet
Blinking screen and clicking noise
The TV is on protect mode. The clicking sound is the protection switch that keep turning the TV off to prevent further damage, this happens when a fault had been detected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
Sep 28, 2008 | RCA L37WD12 37 in. LCD HDTV
Jan 20, 2007 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Televison & Video Logo
3,552 people viewed this question
Top Element Electronics Televison & Video Experts
LP
Are you an Element Electronics Televison and Video Expert? Answer questions, earn points and help others
