Yes, a moen 24 inch towel bar
SOURCE: I'm having trouble removing my
First off you need to pry off the cap thats facing you (most models). Then there should be a little hole on the side for each one that needs an allen wrench to unscrew off the wall.
SOURCE: Tighten up a loose Moen Eva towel bar wall mounted bracket
u have to really push hard up on the spring and at the same time pull towards u
SOURCE: how do I remove the towel bar from the wall?
on both ends look underneath and there is a tiny hole with an Allen/hex head insert u turn counterclockwise wise and loosen srew until you can tilt end upwards towards the wall, reverse to install
SOURCE: I need to remove a Moen towel bar. It has a tab
There should be a "set-screw" (a very small screw) at the bottom of base (fat part) of the towel bar. It screws in to hold the fat part of the bar to the "tab". Loosen the screw by turning it counter-clock-wise. Once loose, the towel bar will lift off the tab. Be careful not to lose the screw!
SOURCE: I've purchased several wall mounting
http://www.moen.com/ this website has videos and how to tutorials. Just pick your product. It has everything you are looking for i checked it out.
There were no instructions included when the items arrived.
