Question about Amana SCRATCH&DENT 25 Cu. Ft. French Doors Refrigerator (BLACK COLOR) AFD2535DEB
Amana refrigerator model (p)ASD2624HEB will not dipense water or make ice. There is a hum from the solenoid when water dispenser button is pushed but no water comes out. There is no filter in the fridge and I can blow air through all of the lines.
Posted by allan dancer on
5 Related Answers
Anonymous
SOURCE: amana side by side ice dispenser leaking water
icemaker wont dump ice
Posted on Jun 19, 2008
Mike Inman
  • 219 Answers
SOURCE: amana fridge water dispenser real slow
u m,ay have to change the filter tubing as well
Posted on Mar 19, 2009
Anonymous
SOURCE: Water dispenser not working
I have a Hitachi R-M800GM.
When i operate the water dispenser, water flows out from the dispenser [not strong flow]. There is also water flowing out at the bottom of the freezer door [hinge area]
I think the line running inside the freezer door may have come loose? If so, how to reattach it? Do u have any layout drawings of how the hose is being connected.
Please help.
Thanks,
Rick
Posted on Dec 11, 2009
Anonymous
SOURCE: Amana free o frost refrigerator
My fridge makes a loud rattling noise when turning off and on
Posted on Dec 29, 2009
John Hall
  • 1218 Answers
SOURCE: Ice maker stopped working
Good day,
A step by step procedure should resolve your problem. If the dispenser is working, you can skip that step.
First step is to take a small paper cup of water and fill the cavity until it is near full. With the ice maker turned on, close freezer door and wait 3 hours to see if it harvests. If not, the ice maker is bad, and must be replaced. If the cubes harvest then.......
Three possibilities.
1. The water supply from the house is not delivering water to the water valve. Shut off the house at the meter, disconnect the line going to the water valve, and with the line pointed into a bucket, have someone turn the valve back on for a 15 second count. The water should come out smartly. If not, the line and it's fittings will have to be replaced.
2. The fill tube from the back of the machine that feeds water into the back of the ice maker is frozen up. You will have to remove the ice maker to visually inspect that tube. If blocked, it needs to be defrosted, but use caution. Too much heat too fast will start to melt plastic and vinyl parts you don't want melted.
If this is the case, then once cleaned out, you will have to change the water valve located in the back bottom rear of the machine because it is leaking during the off cycle.
3. If everything checks O.K. up to this point, you will have to purchase and install a new water valve, and install it.
P.S. Under very rare occasions the electric circuity in the ice maker will fail to send a signal to the water valve. Although rare, it can happen, in which case the best option is to replace the ice maker and water valve.
Posted on May 25, 2010
Amana refrigerator ice maker
You are on the right track since the solenoids control the amount of water reaching the ice maker and the water tap. Sometimes over a period of time the plunger or moving part of the solenoid just gets stuck and a good cleaning will restore it to proper operation.
Mar 16, 2017 | Refrigerators
The ice and water dispenser on my Amana Refrigerator slowly leaks water. Are there repair parts to correct this? And how is the plastic frame containing the dispenser removed from the door?
The problem is most likely not in the door. When the dispense button is pressed it actuates an electric solenoid valve in the rear of the refrigerator that opens and allows the water to flow. Over time the valve seals get worn and the water seeps by. This is what usually causes a drip at the water dispenser. If there is a drip at the ice side then the door is jammed and is not closing fully. This allows the ice at the opening to melt and drip. Hope this helps. Please accept and rate. Good luck.
Dec 08, 2009 | Amana ARSE664BS Side by Side Refrigerator
In door water and ice cube not working
Water dispenser is a simple touch switch in door energizing a solenoid water valve behind ventilation grate above refrigerator. Water tube runs down into and ends at ice dispenser chute. Should hear solenoid click at top of fridge when activate water touch switch. Can unhook discharge side of solenoid valve temporarily to prove water output. If water dispenser tube acts blocked it could be frozen where it ends-look up the hole at the bottom of refrigerator control buttons.
Ice maker is totally different system. No clicking when push ice button but ice in bulk tray may mean the simplest of malfunctions: Ice bin not pushed in the last half inch if ice auger not lined up with drive pegs. There are hidden switches behind ice bin that need to be engaged or nothing will happen in the ice maker: no auger noise, no clicking, no new ice making. Ice bin will be flush with sheet metal if it is in the right spot. Also plastic juice rack won't hang properly if ice bin not pushed in all the way.
Dec 19, 2008 | Sub-Zero 690 Side by Side Refrigerator
Ice maker and water dispenser
Defective solenoid on dispenser line or bad/leaky tubing at exit of solenoid are the likely culprits for your water problem. The lever "Must" move freely to "monitor" the level of the ice in the bin. If stuck or hanging up, the unit goes into "standby mode"......accordianman
Apr 03, 2008 | Amana SXD524VW Side by Side Refrigerator
ICE MAKER and Water Dispenser
very likely a partially clogged filter, but not sure why no light.
Jun 13, 2007 | Amana ARS2661B Side by Side Refrigerator
Amana SCRATCH&DENT 25 Cu. Ft. French Doors Refrigerator (BLACK COLOR) AFD2535DEB Logo
Top Amana Refrigerators Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
