Question about Guess Diamond Collection watch #U10022G1 Watch for Men
I don't know what battery number my U10022G1 guess watch takes. I pulled the battery out and kept it in my purse to replace it but it was lost..All I remember was that it said Maxell but I don
Posted by guerrerojmr on
  • guerrerojmr
    guerrerojmr Mar 24, 2012
    i want to order the battery online b/c I know its way cheaper...like a few bucks so I need the battery number instead of going to a jeweler to fix it for me.
Keely Latto
    New Friend:
    Problem Solver:
  • 5 Answers
Just go to your local jewlers and they will be able to help you.
Posted on Mar 23, 2012
Lost battery foe guess watch U13586L2
I just opened my watch to replace the battery. The number on the battery is: SR920SW
Hope that helps.
Feb 08, 2014 | Newegg Guess Womens U13586l2 Silver...
How do you change a watch battery
Pretty sure you just pop off the back, take out the old battery and put in a new one. Stores that sold watch batteries use to do it for you, some don't now. Liability reasons they say.
Mar 11, 2012 | Watches
How do I set the time on the Stella Tort Glitz watch (ES2795)? I've checked the Fossil website and tried their instructions and they don't work. I have tried moving the hands for the time set in...
Try turning the knob cc and cw a number of times; then pull the knob out hard all the way to pos. 3 and see if this helps. Sometimes it takes a number of times to get it to engage.
Jan 09, 2018 | Fossil Stella Clear Multifunction Watch...
My battery is running dead . Can I have it replaced ?
Yes, the battery for this watch can be replaced. Timex estimates that the battery should last 2-3 years, but that assumes an "average" use of the Indiglo backlight. If you never use the backlight or audible alarms, your batteries would have lasted longer; heavy use of both would have run the battery down more quickly.
If you want to replace the watch battery yourself, you'll need a very fine philips or flathead screwdriver, the new battery, and a bit of patience. It would also be helpful to have a pair of tweezers, but that's not absolutely necessary. If you carefully look on the back of your watch, Timex usually lists the battery type so that you can buy a replacement battery without first opening the watch. If you can't figure out what the numbers mean, take it to a jewelry counter at Target or Walmart, and they should be able to help you decipher it. I don't know which battery this specific watch takes, but many Timex watches use a #1620 or #2016 3v battery. Look for a number like that on your watch back.
To open up the back of the watch, open the strap so that you have good access to the back. If you have a steel band, you might need to slip out one of the adjustment pins to separate the band into halves. Yes, you might be able to take the back off without this step, but it makes it a lot easier.
Place the watch face down onto a soft surface. I like to use a dark towel, so that if I drop one one of the tiny screws you'll be dealing with in a minute, they won't bounce and you can easily find them again.
Use your screwdriver to loose the back of the watch, one screw at a time. I find it very helpful to loosen a screw, then use the tweezers to pick it up out of the hole. These guys are tough to grab with your fingers! Put the screw in a safe place, then carefully remove the back of the watch. A little black neoprene gasket may be stuck to the back or be floating around--don't lose that!
You should be able to see where the battery is kept. On most Timex watches, there's a metal shield covering the watch and completing the power circuit. Using your screwdriver, gently pry the tabs of this shield away from the watch movement, one tab at a time. Try very hard not to snap off any of the little plastic anchors. On a Casio watch I recently serviced, I had to remove the movement from the watch to get at these little tabs; I don't remember ever having to do that with a Timex.
Once the shield is loose or removed, the battery should slide right out. Replace the battery, and gently snap down the metal shield. Turn the watch over to check whether it's working again. If it's not, you may have to push a little "reset" pin on the watch movement to clear the registries. The back of the metal shield usually has instructions on where that little pin is located. If the watch is already working, you won't need to do this.
Closing up the watch is the reverse of what you did to get it open. Make sure the neoprene gasket is back in place--that's what's keeping sweat and water out of the watch--and carefully set the cover back in place. Tighten the screws in an "X" pattern--i.e., top left, then bottom right, then bottom left, then top right. I get all the screws loosely screwed in before tightening them down in earnest. This watch has a plastic case, so you want to tighten the screws snugly, but not over-tighten them so that they strip out the screw hole.
May 10, 2011 | Timex Ironman 30 Lap 53952 Wrist Watch
What type of battery does an ebel (feman) watch use?
ebel keeps that a secret they have a marking on there batteries mine 690 but there is no such after market replacement with this number. ( ebel wants to be the only game in town/ world ) but if you want to replace it your self, witch will void your warrenty 'says' ebel. take the battery out and take it to a jewelry store, and they can match it up ( $5.00 to $6.00 ) or pay $240.00 to ebel to "service" it. clean / new gaskel / batt witch ebel says is necessary to change batt. every 3 years or so. do not take the watch to the jewelery store only the battery , because know one will open it. they will want to send it out to ebel for service big $ also save old batt, because if you ever have to have the watch fixed put the old batt back in and hopefuly they wont notice. to get the battery out read my instructions i have posted its easy. other posts i have read on replacing batt, they don't know what they are talking about. do NOT remove anything but the bezel only. please Read hope this helps you out.
Feb 28, 2011 | Ebel Classic Wave 9090F249725 Wrist Watch
Have open the diesel model DZ9004 and replace both battries, and unable to reboot the digital seconds count on dial. any idea how to get it started?
I had same problem at watch makers and the put the old battery back for the digital secnods count and it started working. I guess the moral of the story is don't replace the digital seconds battery.
Nov 08, 2010 | Diesel DZ9004 Watch for Men
Watch warranty inquiry concerning technical support...‏
Link
Hi Meredith,
Please browse link above for the Guess Support. You might want to try asking them for some battery replacement.
Thank you
Feb 09, 2008 | Guess G66355L Wrist Watch
Guess Diamond Collection watch #U10022G1 Watch for Men Logo
273 people viewed this question
Top Guess Watches Experts
Lisa Christine
Lisa Christine
Tom Chichester
Bill Boyd
Are you a Guess Watch Expert? Answer questions, earn points and help others
