Question about Stihl Ts 410 420 Cut Off Saw Decompression Grommet
What size diamater is pull cord for stihl ts410?
Posted by brendonadams on
anthonysss04
    New Friend:
4.5mm cord
Posted on Nov 12, 2012
1 Related Answer
barterjoe
Joseph Mueller
  • 346 Answers
SOURCE: when fitting coil pack on my stihl ts410 what size
The thickness of a stangard business card. .010-.015
get a free manual from a Stihl dealer like www.arcolawn.com
Posted on Feb 12, 2011
Could someone tell me the difference between a Stihl TS410 and a TS420?
maybe here. http://www.stihlusa.com/WebContent/CMSFileLibrary/InstructionManuals/STIHL-TS-410-420-Owners-Instruction-Manual.pdf
Mar 17, 2016 | Stihl Saws
Stihl saw cuts out when machine is tilted forward on ts410 anybody else have this problem
Fuel pick up will be your problem. Buy new fuel filter and fuel line from in tank to carby. Most likely a split in the fuel line in-tank
Feb 13, 2014 | Stihl Ts410 Ts420 Cut Off Saw Piston Kit...
Stihl Ts410 hard to start and erratic running
http://www.mediafire.com/download/dk8dipzr69pksrk
I've added the breakdown manual for you, have you replaced the fuel and air filters. could be a simple issue of not being able to draw up the fuel from the tank. Stone saws deal with a lot of dust and this seriously effects their running and also their cooling capabilities.
Jan 31, 2014 | Stihl Saws
Stihl ts pull string replace
I've added the TS410 brake down as they're all basically the same and you haven't stated the model to which you're referring.
Jan 30, 2014 | Stihl Saws
Ts410 stihl saw stopped working
Starting procedure for Stihl.
(cold starting)
Place cutoff saw on floor (flat clear surface).
Hold throttle in, while pushing on switch all the way down.
Hold cutoff saw firmly.
Pull starter handle until saw fires, it should then cut out.
Click the starter switch up 1 click to half choke.
Pull starter handle again until cutoff saw fires up. note: it will be reving because the trigger is loched on, (blip the throttle once) and it should go to tick over.
There should be np need to keep playing with the choke when the saw is warm. No need to lock the trigger when starting warm..
Mar 31, 2013 | Stihl Ts410 & Ts420 Cylinder & Piston Kit
Hi, My stihl saw ts410 is really hard when i pull the starter coil, I have changed the cord and it seems as there is no compression could this be seized and if can i fix this myself and what would i need...
It could be seized, or had dust throught the filter wearing the piston and rings, if this is the case it will be a new cylinder and piston required, it is possible to do it yourself if you have a good knowledge of mechanics.
Jan 17, 2012 | Stihl Saws
No fuel getting through ts410 stihl saw
Is it filling the primer bulb? You may have a bad diaphragm or check valve in your carb.
Dec 11, 2011 | Stihl Garden
When fitting coil pack on my stihl ts410 what size gap do you leave?
Dec 27, 2010 | Stihl Ts 410 420 Cut Off Saw...
Stihl Ts 410 420  Cut Off Saw Decompression Grommet Logo
306 people viewed this question
Top Stihl Saws Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Stihl Saw Expert? Answer questions, earn points and help others
