Question about Zoom Audio Players & Recorders
Re: Handy recorder H1.Tried to delete audio files and cant. Micro card full.
I may have accidently moved fomat switch while recording, card reads full but unable to delete files.
Posted by moosic74 on
5 Related Answers
Anonymous
SOURCE: Deleting Files
1. Select folder (A/B/C/D)
2. Select file.
3. Press ERASE once and DELETE will
blink on the screen.
4. Press and hold ERASE for 3 seconds
to confirm deleting. (or press STOP to
cancel erasing file)
Posted on May 18, 2008
Anonymous
SOURCE: SD card full in spite of all files deleted - what do do?
Had this same problem -   Push the Finder button and hold it down .   scroll down the menu to the SD CARD option and click to reformat.
Posted on Sep 09, 2008
Anonymous
SOURCE: WS-110 memory full but no files
well, i resolved this myself by going to the sub-menu, and formatting the recorder to its original state. thankfully, i backed up the files on my computer first, so i didn't lose any data, although i did have to go in and re-set all my preferences on the recorder.
lesson: don't MOVE files from recorder to computer. copy them instead, and do the actual erasing from the physical recorder itself.
i don't know if this was the most elegant solution, but at least it did get my recorder up and running again. i'd love to hear if there is a better resolution out there.
Posted on Nov 29, 2008
Anonymous
SOURCE: Sony ICD-UX70/UX80 digital recorder...memory full problem
If you press and hold down the "menu" button scroll down to the FORMAT selection and press enter. This will reformat the device.
I had the same problem - I think it arose after disconnecting the IC Recorder when it became unresponsive with the computer.
Make sure you transfer all your files first to a computer or back up source.
Posted on Dec 02, 2009
Anonymous
  • 11 Answers
SOURCE: Recovering deleted files from olympus VN-4100PC voice recorder
Chances are there to recover such kind of deleted files from your Olympus recorder.
First things first: DO NOT take any more videos or audio with the recorder that you want to recover files from in case you may quite possibly ruin your chances of voice memo file recovery.
Then connect your device to a PC, and have a try of Photo Recovery (also recover audio, voice memos, video files etc), a data recovery program which is good at recovering media files lost. If you are Mac OS X users, turn to Data Recovery for Mac.
Lastly, I hope you good luck. Again you should remember - the more you use your recorder, the less likely you may be able to recover the deleted files back! So STOP using the device ASAP.
Posted on Jul 14, 2011
2answers
Why a low remain record time on zoom h1 handy recorder when .wav setting in use?
when you record in .wav format, the files ARE better quality, however, they are ALOT larger than a standard .mp3...if you can't tell the 'loss in quality', i would suggest to keep recording as .mp3...but if a .wav is preferred, then i would suggest upgrading the SD card. ..hope this helps.
May 23, 2014 • Music
H1 won't connect via USB
This page has a download for a driver........ https://www.zoom-na.com/products/field-video-recording/field-recording/zoom-h1-handy-recorder
Also try a different cable....... Good Luck!
1helpful
Zoom h1 handy recorder
Download the H1 driver for windows & try different usb cable........
Mar 09, 2017 • Music
Corrupted Audio File on Tascam using Scandisk III 8Gb
You should be able to view the file on a computer. Select the file and delete it. Presumably there was an error after the file was recorded and all you probably have is the file name and a shell of a file. Hence it being only 30K.
There is nothing you can do with the file. And whatever you recorded was lost.
A 40 minute wave file would be massive. Try recording as MP3 for long files. You might be OK at 3 to 6 minutes with a WAV file.
7helpful
5answers
Recover deleted files from cenix vr-p3490
You can recover deleted files with asoftech data recovery software. get the software from link below
Audio Recorder Recovery Software
Please be noted that your voice recorder memory should show as a drive letter in your explorer, if not, you need to take out your memory card and connect using a card reader, or plug-in to card reader slot if there's any on your computer.
You may check out this memory card recovery tutorial also
Deleted a file by accident. Can you recommend
Deleting won't make your files deletedactually. They are just not visible but still in the hard drive which you savedthem at. You can rely on some data recovery programs to help you find themback. You can try Card Data Recovery. Just install this program on your computerand use the function "all recovery", after a while your deleted fileswill be back soon.
2helpful
2answers
I deleted my audio files directly from the computer. Now that I try to record again, the device says that memory is full, even though I have no files on it. How do I reset it to record again?
To erase a selected file, first press the [ERASE] button. Next, press the [+] (plus) or [-] (minus) button to select "ERASE," and then press the [ERASE] or [OK] button.
To erase all files in a folder, first select the folder and press the [ERASE] button for three seconds or longer. Next, press the [+] (plus) or [-] (minus) button to select "ALL ERASE." Finally, press the [ERASE] or [OK] button.
NOTE:
The recorder should be formatted using only by using the internal FORMAT function found in the recorder's Menu. Formatting using the computer may corrupt system files needed to run the recorder, so computer formatting is not recommended. Individual files can be deleted using the computer with no negative effects.
9helpful
4answers
Top Zoom Audio Players & Recorders Experts
Ekse
Paul Bade
Muzahura Frank
Are you a Zoom Audio Player and Recorder Expert? Answer questions, earn points and help others
