Hi i bought a 70cc kazuma secound hand the person i bought it off didnt have any keys for it and there is no battery on it either so i want to put the wires together to jump start it but i dont have a clue what wires go where there is a black and white wire, 1 yellow, 1 white and yellow, 1 red and 1 green cheers
Try this instead, find the connection where the ignition switch plugs into the wiring harness, just fallow the wires, disconnect the plug, hook up a 12v battery to the bike, find the solinoid and use a heavy gauge jumper wire to jump from the side the pos+ battery cable connects to over to the side the starter connects to. The bike should start fine, DO NOT forget to unhook the jumper wire after its started or it will ruin the starter.jumper wire jumper wwire
SOURCE: 2000 yamaha warrior atv will not run
do you have good air intake like new airfilter and good fuel flow
SOURCE: sym jet 50 wiring
Hi, i can't exactly tell you which wire to join to which one, but i can provide you with a wiring diagram, so, hopefully, you can make it out yourself :) http://www.scribd.com/doc/9811756/SYM-Jet-Euro-Electrical-Diagram
SOURCE: How to wire a tach on 05 heritage softail
Locate & route Black lead to ground / 2004-later softail: On the frame strap under the seat directly in front of the battery.
Locate & route the pink lead to Signal / For 2004 & later FXST/C/I The #3 cavity in the connector {39b} on the back of the speedometer. The socket terminal on the signal (pk) lead fits the #3 cavity.
Locate & route the Orange and white lead to power / Ummm.. it's saying for 2004 and later to adapt to the fuse block For earlier [ For 1996 to 2003 softail: locate the power lead (o/w) in the tail lamp pin connector {7a} under the seat behind the right rear corner of he battery.] "here you are looking to run it to a fused line, not directly to power/battery" I hope this helped.
SOURCE: i have a yamaha yfm 350 moto 4 the stator was
MMM, fun... for a start the 3 whites should be right no matter which way they go, the other 4 i'd look at whether they have male or female conectors if possible, if they're bunched together etc, two should be from the ignition, and I think the other 2 are pos. & neg for the coil or coil + and one for earth, depending on the wiring of your bike
SOURCE: need picture or diagram of the 3 coils and
http://www.boats.net/parts/search/Yamaha/Motorcycle/1971/DT1E/parts.html
The above site has full diagrams for the whole bike (1971 DT1E), diagr. below from site shows elec. components, hope it assists you.
