SOURCE: Xerox copycentre c20 fades out on one side of copies
If the scanner will not move you it is jammes on the scanner lock latch. Shut the machine off. Look up in the ares where the copies come out, between the paper tray and the scanner. Look under there, you will see a green latch, about 2 inches long and maybe a half an inch wide. Its the only green item on the bottom of the scanner. Push that latch in toward the back of the machine, then pull it out toward yourself until you feel it snap into place.
That can easily be moved when reaching in to take your copies out of the tray. You can put a piece of tape over it to keep it in place. Orrrrrrr, if you want. when you lift the document feeder, there is that 1 inch strip of glass held in with 2 phillips screws. Remove those screws, take that **** glass out, DO THIS WITH THE MACHINE OFF by the way.... you will see that green latch inside on the bottom. You may have to slide the scanner head out of the way a little bit. When you look at the green latch, you will see 2 plastic clips on the sides, just compress those tabs and pop the latch out of the bottom. Make sure you note the direction you take it out, because you want to flip it around . There is a tab on the latch that will catch better when it it flipped around, You can also just break off the hooked part of the plastic and snap it back in.
You only need that latch for shipping or if your going to send the machine on a ship across the ocean soon. I sort of doubt your going to do that .... Its just a shipping latch, no big deal to modify it .
That should resolve your problem. If not let me know. There are other things we can try,but if the scanner is not moving, there is a 99.999999999999999999999999999999999999999999 percent chance the latch is just out of position.
SOURCE: Xerox copycentre c20 paper jam in 2 how do i get it out please
Unplug the machine, open the right door. Get a phillips screwdriver.
Look on the upper portion of the paper path, you will see an assembly with yellow waning stickers that say HOT. There are 4 silver screws on that fuser assembly. Remove those screws, and unplug the white connector. Pull back toward yourself to remove the fuser.
Lay it down and remove 2 silver phillips screws , it will open up and you can remove the paper. Make sure the machine has been off for a half an hour or so, It is hot. Take a good look at the black aluminum coated roller on top. See if it looks smooth and clean, If it has a lot of toner built up on it, you will have to repalce the fuser or it will continue to jam and give you ghost ( light reprinted) images up and down your page.
Also the M20 does not handle large black ares on a page such as a picture or magasing cover being copied. Largs solid areas tend to stick to that heat roller. If you do copy a photo, try and allow about 2 inches on the top of white. Just move your original down on the glass about 2 inches from the edge. 2 inches to tie right of the edge of the glass.
SOURCE: Our copier makes light copies.
Most likely, you need a new toner cartridge, part number 106R01047
SOURCE: My Xerox copy center C20 will not turn on. Is
No need 150 dollar.You repair it simple coast may 20 dollars.Please call a technician who repair it in your area.please send me comments where you live?
SOURCE: Xerox copy center C35 - Replace Xerographic module
You can try this.
Press the access button, You will see a button called Enablement Code, then enter this number. *33886714351 .
Make sure you entter the * first, that is the button bottom left on the keypad.
That should allow you 5000 more pages. But it can only be done once. May or may not work on that product. But thats all I know.
