LG WM2277H Front Load Washer Logo
Question about LG WM2277H Front Load Washer
The Door is very stiff when opening and closong
The hinges do not move very easily
Posted by keith baxter on
Poppa Maddo
    Sergeant:
  • 372 Answers
Disconnect machine from Power.
Spray some WD40 or similar product over the hinges while you work the door into the closed and open position, until it all loosens up.
If this does not work then the hinges must be so badly corroded inside that they will need replacing.
Poppa
http://www.cdbaby.com/cd/poppamadison
Posted on Oct 03, 2013
1helpful
Door on front load LG WM2455H* seems stiff when opening now. Works sometimes fine and other times starts then stops and I get dE code. Happening more often now but not all the time.
On ur model soap and softener can drip down on door hinge on inside of front panel of unit. It 'rusts' the hinge and causes it to be hard to pivot. That also puts extra pressure on the door lock mechanism and sometimes misaligns the closing. The hinge double pivots. Sometimes taking front off and lubricating the hinge will free it.
How do I remove oven door
open the oven door all the way and look down at the hinges. there is a little locking clip that you swing into position that locks the hinge from closing. it might be stiff and need some cleaning depending on how old and dirty your oven is. Also you might have to push down on the oven door to make the hinge open fully to get the locking tabs into place. making shore that the locking clips stay in place and hold open the hinge as you lift the oven door slowly towards its closing position and you will see the whole hinge lift up from inside the oven cabinet and the door will just lift out. be careful not to catch your fingers. make sure the looking tabs stay in place during removal as the hinge is very hard to get back into this position again. re fitting is the reversal making sure that you have pushed the base of the door all the way back into the cabinet and push down on the as to open it to release the tabs.
Sep 23, 2016 • Ovens
Hi, I have just purchased a pair of hinges for my Lamona HJA3320 oven and they arrived in the "oven door closed" position. However, to fit to the oven they need to be in the "part open" position, and I...
i never worked on your brand but have installed hinges on other oven doors,install the hinges to the door,put the door back together,i have a piece of pipe that's hollow,have one person hold the door down while you use the pipe to position the hinge,just stick the arm of the hinge into the open middle of the pipe and you can easily move the hinge and set the lock on the hinge to the position you want it to be,maybe a car jack handle will work or a plumbing piece of pipe,doesn't have to be long like 2 ft. long this will give you the leverage to open it no problem,if you try to do it by hand use a towel or gloves so you don't tear up your hand.hope this helps it works for me.
Jan 14, 2018 • Ovens
Whirlpool GMC275PD build in electric double oven
I have a different model Whirlpool oven but if the door opens downwards then there are usually two smalll catches on top of the main hinges. Lift these up (they can be quite stiff) away from the oven, partially close the door and it should lift upwards to free the hinges.
Hope this helps
Sep 14, 2009 • Ovens
1helpful
The door can barely be opened on a Wolf oven. The hinges are
I called Wolf customer care and they are sending me a new door. No Charge. NOW THATS CUSTOMER CARE.
Jul 09, 2009 • Ovens
2answers
1995 Chevy suburban back door hinges too stiff
Lubricate the hinge or the hinge will have to be replaced.. I recommend wd40 first, then a finger tip amount of grease on top of hinge pin. the oil from the grease will keep the hinge constantly lubricated. It's not too late.
Door very stiff won't close tight
I have the same problem with the side doors of my 04 express. I put penetrating oil on the hinge pin with a hypodermic needle (hard to find). It is important that the oil gets into the hinge. I bent one set of hinges and broke a hinge because I waited too long to oil the hinge. The door may not close correctly because the hinge may be slightly bent. Keep all other hinges well lubed especially during the winter months when the hinges can be exposed to road salt. Fixing a bent hinge is difficult at best.
Jenn-aire JJW8530dds
It might be because when the door was completely removed ( which they do rather easily for repairs and moving) it wasn't put back properly.
I would suggest you remove the oven door and re install.
You do not remove any screws or anything like that to remove the oven doors.
When you have the oven door open squeeze each hinge and shift then both outwards it will release the door from the hinge, the hinge stays on but the door will slide off the hindge. Afterwards check the alignment and reinstall the oven door
2answers
Viking Ultraline Professional Gas stove
It is visible the hinges /w40 has extension nozzle spray the hinges a few minutes open slowly/ by moving little by little until the lubricant or oil penetrate the moving parts of hinges ,
Top LG Washing Machines Experts
Marvin
Marvin
W.L.
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
