Husqvarna logth2448t riding tractor 48 inch mower. mowing when blew fuse, replaced fuse and tractor ran fine but mower wouldnt engage replaced pto switch and seat safety switch works fine, put 12 volt power supply to clutch and it engages and disengages fine replaced battery also hooked clutch up and pulled pto switch clutch will not engage, parking brake is set doesnt seem like power is going to clutch from pto switch
SOURCE: Knocking in mower deck or belt clutch when engaging blades, motor bogs / slows down
YOU MAY HAVE A BENT BLADE OR EXESSEIVE BUILD UP UNDER THE DECK
SOURCE: engine cutting off after engaging the pto (mower deck) JD 317
its likely to be a switch playing you up try hard wireing the switch to see if it stops this cutting out first, do one switch at a time till you fine the one playing up
the charging system is workink fine
with the old pto switch when pulled up nothing would happen, put in a new pto switch started tractor pulled up to engage mower decvk and imediality blew the 20 amp fuse. when putting 12 volts to clutch it will engage and disengage ohms and amps all read to specs charging system works within specs and air gap in clutch all to specs looked at all wiring all looks good, and seat switch all read to specs, but still blows fuse when engaging blades
I will try that think
