Question about HP Pavilion Computers & Internet
OLD DV6 HP laptop. LCD problems. horizontal thick bar lines on the bottom of laptop monitor
I purchased this note book (HP Pavilion dv6-2140ee, Windows 7-64 bit (Service Pack1),Display- NVIDIA GeForce G105M) from Abu Dhabi (U. A. E.). and now I am facing a serious problem in my display monitor. There is a horizontal thick Bar line at the bottom of display. It started as a small line and gradually increased to 105 cm in size. and now it has been remaining at this size for 6 months. So kindly help me to know the reason behind this problem and what is the solution ?. Hope you will reply me soon and thanks in advance. Regards, Retheesh Xavier xxxxxxxxxxxxxxxxxxxx
Posted by Retheesh Xavier on
Michael Green
  • HP Master
  • 3,799 Answers
Take it back to the retailer. Unless it is more than a year old. The graphics chip or screen has failed.
Posted on Mar 23, 2012
Testimonial: "I think You are right.thanks for suggestion and i am looking for a service centre in mumbai"
  • Anonymous Sep 12, 2018
    bad LCD (no photos posted of screen , oops)
    so bad LCD or CCFL tubes dead.
    or loose cables to LCD.
    this is a 2009 PC and 2008/0
    can also have the GPU chips bad called the "lead free BGA solder ball fiasco"
    for those with DV6 ask for test to prove what is bad.
    this CCFL PC, has only 1 tube. so its
    dim, yellow ,or dead or intermittent
    will not go dead in one area 1 of 4 possible like PCs. so is LCD or GPU failure.
5 Related Answers
Anonymous
SOURCE: hp pavilion f1523 lcd monitor
You are not alone with this problem. Some lines (like mine) run vertically rather than horizontally. The solution - sue HP. These screens have a known fault ie the Nvidia graphics chip is known to be the culprit. The company knows all about this issue but expect us to pay to put it right - sue them, you can do it online for around £35 (UK).
Posted on Oct 29, 2008
antiochpc
Kevin Shafer
  • 1314 Answers
SOURCE: Vertical white line on laptop display
Yes, this is a defective screen. The only fix is to replace the screen. It's called a column of dead pixels. Since it is under warranty, contact HP to have them warranty it out or take it back to the place you purchased it from for an exchange. Please take a moment and give this answer a good rating of fixya. Thank you.
Posted on Dec 26, 2008
Anonymous
  • 67 Answers
SOURCE: Display has lines that run through it
they can be horizontal. I think your graphics card on your motherboard is bad. you should consider sending it to acer so they can replace it with a new one.
Posted on May 18, 2008
pontelemon
pontelemon
  • 538 Answers
SOURCE: Flashing block patterns and zigzag lines on lcd display
Common problem.
There are small VRAM BGA chips.
1 or 2 of them needs REFLOW.
Basically needs board service.
Posted on Mar 20, 2009
Anonymous
  • 7 Answers
SOURCE: hp pavilion dv9267ea problem with nvidia Display
I want to share my experienced with 2 units HP notebook; Presario V3000 (V3737tu) and Pavillion dv2000 (dv2505tx).
The notebooks have problem with Intel & NVidia VGA driver , but all the problem now solved by using microsoft display driver (Standard VGA), this way can solving the problem of lowest 4-bit (600x480) and spliting into 8 screen that makes me upset.
This like a virus/worm/malware/trojan or whatever that can makes us very upset ... please also do scan & clean virus/worm/malware/trojan with all free that can be download ... (I am using AVG, Norman Malware cleaner, Virus effect remover, PCMAV) ... Now, 1 of my notebook now can use back NVidia driver again .... the other is still scanning/cleanning, still using Microsoft VGA Standard driver and still working well ...
[email protected]
Posted on May 19, 2009
Henches problem in hp pevilion dv6
Chandanipraj,
1) Hinges example,
http://www.ebay.com/itm/New-LCD-CCFL-Screen-Hinge-Set-Left-Right-for-Hp-Pavilion-DV6-15-6-Series-USA-/261104644529?pt=US_Laptop_Screens_LCD_Panels&hash=item3ccb0cb1b1
2) HP Support > Pavilion dv6-1050us Notebook PC > Main Supoort page,
http://h10025.www1.hp.com/ewfrf/wc/product?product=3860586&lc=en&cc=us&dlc=en&lang=en&cc=us
Manuals >
Click on -
HP Pavilion dv6 Entertainment PC - Maintenance and Service Guide
It's a Service Manual,
Pictorial guide in replacing the LCD screen, and also replacing Hinges,
http://www.insidemylaptop.com/replace-broken-screen-hp-pavilion-dv6-laptop/
Just to add;
http://www.insidemylaptop.com/disassemble-hp-pavilion-dv6-laptop/
For additional questions please post in a Comment.
Regards,
joecoolvette
(Hi from the USA)
Oct 18, 2012 | HP Pavilion dv6-1050us Notebook
My HP laptop monitor has a horizontal line
  1. Connect an external monitor, check if display is OK.
  2. If Display is OK, no horizontal lines then your LCD need to replace.
Aug 20, 2010 | HP Pavilion Notebook
I have a fine horizontal line running 2/3rd's of my hp mini note book.should i be concerned?
This could be a hardware issue with the LCD screen of display card. To confirm the same, connect an external monitor and check if the same line appears on external monitor. If external mitor works fine, then its a LCD defect. If you have same issue on both LCD and External monitor, then it could be due to display card. In either cases you may need to take to service center.
May 22, 2010 | HP Mini 1000 Netbook
HP Pavilion F1903 flat screen monitor dimmer with grey lines
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 12, 2010 | HP Pavilion F1903 19" Flat Panel LCD...
My HP laptop's screen (the bottom end) continuously blinks
If you have already hooked up an external monitor absolutely its the ribbon cable connecting the LCD to Laptop If its less then a year old get the warranty for replacement
Aug 10, 2009 | HP Pavilion dv6000z Notebook
Hp pavillion dv6-1030us just order my new screen how do i take the front and back bezel off looking for a video link not finding all the screws on front thanks
The procedure to replace the display is outlined in the maintenance and service guide.
Refer to the Display Assembly beginning on page 81 for the "complete" disassembly instructions.
http://h10032.www1.hp.com/ctg/Manual/c01758220.pdf
The maintenance guide gives you step by step procedures to remove the monitor and most importantly... how to remove the bezel "properly".
Jul 21, 2009 | HP Pavilion dv6-1030us Notebook
Flickering, jittery image, white horizontal flashing lines
this is real old right
no photo off i messing up, how can we guess, what you see?
amazing....
my guess power pack shot.
i guess you cant barrow a monitor and try that?
2nd guess blind, the back light failing
or is damage if it was hit, the LCD will have damage
gently flex the frame goes nuts, bingo.
Mar 02, 2017 | HP Pavilion F1703 17" LCD Monitor
Hp pavilion f1523 lcd monitor
Oct 02, 2008 | HP Pavilion zd8000 Notebook
Visual problem
The line you see can be because of faulty LCD or faulty Graphic Card.
To make sure what is the actual cause of the issue, try the steps listed below for which you need a desktop monitor.
Turn on the Notebook and connect the Desktop Monitor the VGA Port of the Notebook and turn it on.
Now, hold the FN key and press the F4 key once to toggle the display between the LCD and the Desktop Monitor connected.
If you see the line on the Desktop monitor also, the issue is with the Graphic Card. However, if the line appears only on the LCD of the Notebook and not on the Desktop Monitor, the issue is with the LCD.
The Notebook needs to be repaired in both the situations.
However, if the issue is with the Graphic Card, the motherboard needs to be changed since the Graphic Card is soldered on to the motherboard. Additionally, if the issue is found to be with the LCD, the LCD Display  of the Notebook needs to be changed.
I recomend you to go for a new Notebook if you are not comfirtable since the Motherboard or LCD Replacement will cost you a bomb...
Hope this helps...
Sep 15, 2008 | HP Pavilion ze2000 Notebook
Computers & Internet Logo
541 people viewed this question
Top HP Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
efs_perpends
efs_perpends
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
