Question about Texas Instruments TI-84 Plus Calculator
How to fix the graphing on a TI- plus texas instrument
I am getting an error sign when I use the Y= and then try to graph
Stevan Milanovic
    Sergeant:
  • Texas Instru... Expert
  • 267 Answers
INVALID DIM error message may occur if you are trying to graph
a function that does not involve the stat plot features. The error can be
corrected by turning off the stat plots. To turn the stat plots off, press
2nd, stat plot , and then select 4:PlotsOff.
Posted on Mar 23, 2012
5 Related Answers
Anonymous
  • 4 Answers
SOURCE: TI-83 Plus Graphing Error
Try zoom 6
Posted on Feb 03, 2009
Sada786
  • 88 Answers
SOURCE: I can't graph on my ti-84 plus silv. edition
More than likely, you've put in a number in the xmin or xmax that is not correct. Example....you put in an xmin of 10 and an xmax of -10 which would be backwards. This could also happen in the ymin or y max.
The easiest way to fix this is to press zoom 6 which wil get you back to the default graph of xmin of -10, xmax of 10 and ymin of -10 and y max of 10.
If you can't see your graph on this screen and need to change the window, just be sure the number in the min for both x & y is smaller than the number in the max. You change your window size by pressing the window button.
Posted on Aug 15, 2009
k24674
  • 8091 Answers
SOURCE: How to plot a graph on TI-83 plus texas calculator?
Prepare calculator to graph
Turn StatPlotsOff to avoid errors:
Press [2nd][STATPLOT][4:PlotsOff][ENTER].
Setup Graph type
  • Press [MODE] key.
  • In Mode set up screen, make sure that the angle unit is the degree.
  • Use the arrows to move cursor to 3rd line to highlight {degree} and press [ENTER]
  • On same screen, verify that Func is highlighted.
  • If it is not, use arrow to highlight Func and press [ENTER] to validate.
  • Do not worry if you do not have exactly the same screen as in the screen picture (We may have different OS Versions)
Entering the functions to draw.
  • Press [Y=] to enter function editor.
  • Type in a function
  • Press [ENTER] at the end of each function.
  • Before pressing [GRAPH], make sure that all the = signs that define the functions to be graphed are highlighted white on black. If one is not highlighted, use arrow to move cursor on the sign and press [ENTER].
  • In the screen capture 4 functions are slated to be drawn.
Selecting the Graph Style (You may ignore this now, because it is unimportant for just one graph)
  • Select the graph style: The small piece of line to the left of a Y that defines a function is the style.
  • Move cursor on it and press [ENTER] .
  • Each [ENTER] (on same line) selects another style.
  • On the next screen you have all the styles available on the calculator.
  • Do not select the bubble on line 6: It is for animations. It will not leave a trace at the end of the plot.
Drawing the Graphs
  • Press [GRAPH] to see the graphs.
  • If one of them is missing, verify that its = is still highlighted, then use the [WINDOW] to set the Window dimensions,
  • Here are the dimensions of the standard window
ZOOMING
You can also press [ZOOM] to adjust.
The selection 6:ZStandard sets the dimensions as on the screen Titled Window (above).
In the window screen you can set Xmin=-180, Xmax=180, Xscl=10, Ymin= -0.6, Ymax= 1.5, Yscl=1. The minus here is the change sign (-) to the right of the [.] dot.
Posted on Mar 14, 2010
Testimonial: "Thank you so much for your kindness in helping me. "
k24674
  • 8091 Answers
SOURCE: err:no sign chng
If you were trying to find the roots (zeros) of an algebraic equation with the solve( command or the interactive solver you might have supplied an interval where the function is always positive or always negative. If the expression is always of the same sign on an interval, the interval does not contain a root.
  • If you extend the interval, the procedure may not converge fast enough and the calculator may not find the solution.
  • Abetter way to do it is to sketch the graph of the function and use the graph to choose a reasonable interval that extends on both sides of the root, and a better initial guess.
If you were doing some financial calculations,
  • You attempted to calculate the I% variable when FV, N*PMT, and PV are all positive, or all negative.
  • You tried to calculate Irr( when neither CFlist, nor CFO is positive
  • You tried to calculate Irr( when neither CFlist, nor CFO is negative
Posted on Jun 20, 2010
  • 102366 Answers
SOURCE: TI-83 Plus Calculator: My TI-83 reads "INVALID DIM" when I try to graph a...
You're probably trying to graph a function that does not involve stat plot features. You can correct this by turning off the stat plot features. Press "2ND" "STAT PLOT" and then select 4:PlotsOff.
Posted on Jul 12, 2010
How do I graph a simple equation, without getting an error 07 message? y=-1.5x+3
Error 07 Syntax
Means you made a typing error while entering the equation. Using the minus sign instead of the negation sign (change sign) (-), can produce a syntax error. Maybe you need to explicitly type the multiplication sign
y= (-) 1.5*x +3
Try entering it as 3 - 1.5*x
Jun 11, 2014 | Texas Instruments TI-86 Calculator
When I try to enter a simple equation and graph it, I get error 07 message instead of graph.
Error 07 Syntax
y= (-) 1.5*x +3
c3b67db6-adc8-4b0c-8e71-dc94a9bdbeb0.png eb28a330-c2e9-4879-857f-1e41bfe8515a.png
Fix the ERR:INVALID DIM message on my TI-84 plus, please.
INVALID DIM error message may occur if you are trying to graph a function that does not involve the stat plot features. The error can be corrected by turning off the stat plots. To turn the stat plots off, press 2nd, STAT PLOT , and
Mar 26, 2012 | Texas Instruments TI-84 Plus Calculator
On my ti 84 plus calculator, i try doing graphs and it gives me a "invalid dim" error. Any suggestions to get the graphs working
Sep 26, 2010 | Texas Instruments TI-84 Plus Calculator
Everytime i try to graph i get an error saying invalid dim on my TI-84 plus calculator
May 19, 2010 | Texas Instruments TI-84 Plus Calculator
Can not use graph function
How do I fix my Ti 83 calculator's window range error and do the graph?Because without that fixed I can't do my graph atall.
Oct 19, 2008 | Texas Instruments TI-83 Plus Calculator
Graphing
You're probably getting a dimension error trying to graph a function that does not involve stat plot features. You can correct this by turning off the stat plot features. Press "2ND" "STAT PLOT" and then select 4:PlotsOff.
Dec 04, 2007 | Texas Instruments TI-83 Plus Calculator
Texas Instruments TI-84 Plus Calculator Logo
187 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Paul Bade
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
