I have a Staples Paper Shredder, Model No. SPL-TMC16A, the Anti Jam keeps stopping the shredder even though there is not more than 16 sheets in the shredder. What can be done to fix this?
ray gallant
    Top Expert:
  • Office Equip... Master
  • 69,253 Answers
Put in a lot less each time
Posted on Mar 19, 2016
2 Related Answers
Mr Tech Geek
  • 133 Answers
SOURCE: papper jam
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} UNPLUG THE UNIT FIRST…….OKAY!!??
If this shredder is like most nowadays, they have a sensor that detects paper when it’s put into the shredder and a sensor when it exits the unit. Look for a small black squares with another square directly across from it. (<sensors) Make sure nothing is between any of these sensors.(and clean if you have to) (plug in and test again) (then unplug if that didn’t fix it) There is a piece of cut paper that’s stopping the motor’s torque from reversing or feeding the cutting rollers. Sometimes a plastic gear breaks. If they are ….its trash!!…..You will have to take the covers off to see. Eyeball it real good…(put your glasses on if you need to) If no gears are broken, look on the ends of the assembly that holds the two cutting rollers together.
Before we get to far…..check and see if there is a breaker (or fuse that has blown) The book sez it’s a 12 sheet shredder…..The manual should tell you what weight of the paper being shredded . (the maximum weight of the paper) 20lb. bond etc…..If the fuse is blown replace it with the same size..(read the small numbers on the end of the fuse and don’t use anything else!!!....(fire hazard!) If the fuse isn’t blown check and see if the power outlet is good…… If all is good, make sure when you take it apart the two cutting rollers that you put all the screws back in the same place they came out of …(very important) (write down the positions if you have to) When putting the unit back together…don’t over tighten . The plastic molding blocks strip out very easily. Don’t lube anything. Paper fibers will be drawn toward anything lubed……(shortening the life of the unit) Good Luck!!!!! Tell me if this helps!!!!
Mtg
Posted on Apr 30, 2009
Anonymous
SOURCE: STAPLES TITANIUM CUTTER (SPL-TMC16A) CONTINUES
can't solve the problem, but wonder if I could get an owners manual for this same model (SPL-TMC16A)
Posted on Jan 07, 2011
What lubricant do you use for a Staples SPL-XC240D and where do you lubricate it?
Staples actually sells shredder lubricant. It comes in a small squeeze bottle. You actually are lubricating the shredder teeth themselves to keep them sharp and prolonging their lifetime. You simply take a piece of paper you are about to shred, run a bead of the lubricant across the sheet and feed it into the shredder. Done!
Mar 04, 2015 | Staples Office Equipment & Supplies
How do I fix a staples spl tmc 10 paper shredder that does not feed?
It may be clogged with shredded paper. With power removed, examine the shredding mechanism and remove any bits you find. You may not be able to remove all of the bits but enough to restore operation.
Oct 09, 2014 | Office Equipment & Supplies
Staples shredder parts
You can try cleaning it and maybe limiting shredding to one sheet at a time.
Jan 14, 2014 | Office Equipment & Supplies
Staples Shredder SPL-S302D I think I need a new
Take a look underneath where the shredding mechanism is and remove every bit of paper. It is a messy job, but necessary. When you finish, the shredder probably will function normally. Also, ignore the advertised sheet capacity and feed one sheet at a time. Stop when the bin is half full, dump it, and repeat the bit-by-bit cleaning process. I just went thorough this exercise yesterday!
Feb 16, 2018 | Office Equipment & Supplies
My Staples Shredder, model # SPL-S302D will stop shredding in the middle of a job or immediately after starting to shred. It is a strip-cut style shredder, I use lubricating sheets once in a while on it,...
You can clean the sensor with a alcohol and be sure there is no jam occur. If it doing fine then it's work and there's no more problem. Always clean it, a jam can cause motor to heat up and it's winding will be burnt.
I hope my advice help you.
Jun 06, 2011 | Office Equipment & Supplies
STAPLES TITANIUM CUTTER (SPL-TMC16A) CONTINUES TO RUN WITHOUT STOPPING AFTER PAPER HAS BEEN SHRED. THE FORWARD LIGHT FLASHES.
Dec 16, 2010 | Office Equipment & Supplies
Runs continuous when turned on, but stops when paper is inserted
I owe this to a Steve-EE.
Mine was the LED where the paper feeds. $1.69 for a 2 pack.
http://www.radioshack.com/product/index.jsp?productId=3107633
May 09, 2010 | Staples SPL1050LBRX (CrossCut) Shredder
3,280 people viewed this question
Marvin
Marvin
