Question about Dell Studio 17 Laptop
Dell studio 1749 wont turn on and the white light blinks 3 times with ac power
My laptop was sitting up on it's side and fell. Since then it won't turn on. battery is fine, but when it's plugged in the power light blinks 3 times and stop. no start up, not a peep
5 Related Answers
Anonymous
SOURCE: laptop won't turn on
I am facing a similar problem with 5160 and my power button will not power up the laptop. I presses the shift key, it got powered up (offcourse only fan started but the screen is black)
Try pressing shift key to power up.
Posted on Jul 14, 2008
Pyrhyc
Ryan Rogers
  • 2028 Answers
The blinking orange battery light generally indicates that the battery isn't working properly, usually going out and not charging properly. In this case, since the adapter will not power the machine without the battery, and it should, I'm going to say that the adapter is going out and not getting the proper amount of power to the system. Try replacing the adapter. Be sure to replace it with a Dell replacement, the Targus brand universal adapters do not work well with Dell machines, and in most cases won't work at all.
Posted on Jul 15, 2008
Anonymous
SOURCE: dell latitude d600 blinking battery light
Sometimes a systemboard will cause this,
Posted on Mar 16, 2009
Anonymous
SOURCE: Dell inspiron 9300 wont power up/good battery and charger
check if your systemboar power is on or not, and also check if the fan is spinning or not. If not try and reset your processor.
Posted on Apr 20, 2009
Anonymous
  • 10 Answers
SOURCE: I have TWO dell studio 17 1737 laptops. One of
it could be the connection for the battery is damaged in some way, my advice would to take it to a repair shop, let the pro's have a look, power problems should always be dealt with by someone qualified, for you own protection. good luck with it.
Posted on Aug 30, 2009
Dell studio 1749 battery indicator led 3 white flashes
Hi Chris,
There is a possibility that the battery is on the verge of failing. Request you to try following the below steps which might help:
    (1)You may try running an online diagnostics using the below link:
    http://dell.to/189uUNy
    Click battery life and run diagnostics.
    Make a note of the error codes that appear (if any).
    (2)Try using a known good battery and see if that makes a difference. Also let me know what code appears when just the AC Adaptor is plugged in.
    Thanks and Regards.
    Kiran Kumar.
    #iworkfordell.
Dec 17, 2014 | Dell Studio 17 (1749) Laptop black -...
Dell 1555 Studio laptop won't power up. After the power cord is plugged in, the LED light on the side blinks white once and orange four times. What could be causing it and how can it be remedi
have you tried a different power source or power supply ,maybe you can borrow one from a friend and try and if that don't work you might have to take it apart and see if your power cable is seated properly in the motherboard
Sep 28, 2014 | Dell Studio 1555 laptop
My mini 10v Dell won't charge the battery, and if I take out my battery to just run on power it won't turn on. The light that lights on if power is on blinks for a sec or two and shuts back of
take the battery out and hold the power button for like 15 seconds. then put battery baCK on and plug it in but do not try to power on. lets saee what goes? remember not to power on
Jan 31, 2013 | Dell Inspiron Mini 10v Netbook Computer
MY COMPUTER SHUT DOWN UNEXPECTEDLY AND WON'T TURN ON AGAIN
I usually try to hold the power button for >5 seconds to reset it. No lights even when plugged in?
Jan 01, 2013 | Computers & Internet
Dell studio 1558 wont start up beeps 7 times
Your beep codes indicate a processor failure, did you purchase a new processor with the MB or did you use the old one?
Nov 23, 2012 | Dell Studio 1558 Notebook
Dell inspiron 1520 won't turn on.
Remove the battery from its compartment on the side of your Dell Inspiron laptop computer.
Remove the power adapter from its plug on the side of the Dell Inspiron (if your laptop is currently plugged into a wall outlet).
Press down and hold the "Power" button on the laptop for one to two minutes. This will dispel the excess electrical current that is built up inside the laptop.
Put the battery back inside the compartment of your Dell Inspiron.
Plug your power adapter back into the side of the Dell Inspiron. Press "Power." Your laptop computer will now turn on.
hope this helps
Oct 08, 2012 | Dell Inspiron 1420 1501 1520 1521 1525...
Won't turn on?
stop leaving it plugged in all night it will over charge ur battery if doin so
Sep 07, 2012 | HEWLETT-PACKARD Computers & Internet
Gateway M 6843 won't turn on
You may have already done this, but remember many laptops require that you remove the battery for about 30 sec. as
well as disconnect the AC power to reset them.
Always try this when everything appears completely dead.
Source: pcsupport.com <<<and it's worked
Aug 28, 2012 | Gateway M-6843 Notebook
Dell Studio 17 Laptop Logo
582 people viewed this question
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
