2000 Ford Windstar Logo
Posted on Mar 22, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My fuse box has missing fuses need a diagram so i know what fuse goes where and the amp!
Anonymous
Level 3:
  • Master 4,803 Answers
  • Posted on Mar 23, 2012
Anonymous
Master
Level 3:
Answers
4803
Questions
0
Helped
2962175
Points
18833
The diagram you are asking for is on page 185 in the 2000 Ford Winstar Owner's Manual. (You most likely already have the diagram in your glove box.)
However, if your Owner's Manual is missing, you can download a free PDF version at the following (direct) link.
2000 Ford Windstar Owner's Manual
5 Related Answers
Anonymous
  • 186 Answers
  • Posted on Feb 27, 2010
SOURCE: free fuse box diagram for ford explorer 2002 XLT
Heres the definitions of the fuse numbers:
graphic.aspx?mod=reptiff&module_id=1&session_id=%7b812b1a44-e9f7-498d-9233-3843c35aa6d4%7d&image_guid=00323000&print_bw=0& graphic.aspx?mod=reptiff&module_id=1&session_id=%7b812b1a44-e9f7-498d-9233-3843c35aa6d4%7d&image_guid=00323003&print_bw=0&
Anonymous
  • 13 Answers
  • Posted on Jul 23, 2008
SOURCE: I need a Fuse box diagram for a 1999 Ford Contour
do a google search and that should tell you where to get one from or try a junkyard or maybe the ford company can help.
Anonymous
  • 1201 Answers
  • Posted on Jan 21, 2009
SOURCE: no dash lights on a 1985 ford f150.. replaced all the bulbs, fuse box cover is missing and no manual, so which fuse do I check?
Facing fuse box, left hand side, bottom fuse
Anonymous
  • 3533 Answers
  • Posted on Mar 21, 2009
SOURCE: fuse box diagram for my 1989 crown victoria
it should under the lid of the fuse box and in the owners manual if no manual try here for one online www.edmonds.com
Anonymous
  • 3533 Answers
SOURCE: diagram and to know what each fuse is for on a 2000 ford taurus
the diagram is on the lid of the box and in the owners manual if no manual try one online from www.edmonds.com
1990 Toyota Camry Fuse box cover missing on driver's side
Chilton's Manual 1983-92 is almost useless.. says to check the covers. With that many items seeming to be electrical (& likely fuse) related, I think I'd buy a pack of fuses & replace all of the bad ones, & keep some spares around. ALTHOUGH... for the window defogger, environmental control sys., power door locks,power tailgate lock, sunroof & shoulder belt it DOES say to check the circuit breaker in the driver's side (or passenger side) kick panel with the fuses.
There is a reset hole (might try a pulled open paper clip... amazing how these can come in handy & how cheap these are! Not having a silly paper clip can be a real pain! Try keeping a few in the glove box! ) If it re-trips immediately. Use an ohm meter to check both terminals of the breaker. Chilton's says if not "as specified, replace the circuit breaker."
To change the breaker, turn the key off, disconnect the neg (-) battery cable, unlock the circuit breaker stopper, then pull it from the socket.replace (do same in reverse to re-install, making sure you have the same amp breaker as the one you pulled, if you need to replace it.)
*NOTE: I'd suggest checking a junk yard for a cover plate for your fuse box. It might save you a big hassle over a little thing on the road in the future. (Or at least keep the owner's manual in the dash) Having the cover on can keep moisture, dirt, etc. out of your fuse box, so I'd see if you can find one in a junk yard... just be sure same engine, year etc. (or if it fits & is a different config. of fuss, I'd copy the one (re-size if necessary) the schematic from the owner's manual, laminate it (a lot of copy shops can do this for you), the adhere it to the inside over the incorrect diagram. That way you'll know what fuse goes to what & there should be a puller tool & space for extra fuses in there (or yo can put them in the glove box.)
Best of luck & Ty for sharing where the actual schematic is & what fuses go where! Mine's out in the car & I'll have to book mark it, in case I ever need it!
12helpful
2answers
Lost Fuse Box Diagram - Altima 2005 2.5L
i need to know what ENG CONT AND ENG MTG means on the fuse box of my 2006 altima.
Fuse Box
http://www.carfusebox.com/suzuki-forenza-2005-under-dash-fuse-boxblock-circuit-breaker-diagram/
26helpful
4answers
1988 chevy silverado fuse box
I hope this helps a little, you said the fuse box panel is gone....so how do you know some fuses are missing?
I just bought a 1988 silverado also, the wipers ,power windows and windshield washer fluid only work "when they want to" I think I have a bad ground somewhere.
1helpful
3answers
Top Ford Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Ford Expert? Answer questions, earn points and help others
