Sansui A-909 LED indicator(peak power meter)
Hi, I have a Sansui A-909 amplifier, witch needed repair because it had no sound. But in the repair process the technician somehow burn a part, IC - LC 7815 H analog switch and then the lights for selecting Phono, turner and tape1 went dead, but the tape 2 option work, but the peak power meter (LED input signal indicator) went dead as well. After I managed to find a replacement IC, the red light for the input function come back on and everything seems to work ok, but the peak power meter for both channels is still dead, only the two pilot lights on the bottom of the LED indicators lights up, but nothing moves like before when the sound came through
Posted by Jacques on
JonSnell Electronic
    Top Expert:
  • Audio Player... Master
  • 30,888 Answers
Check you have 14 volts on pin 3 of the driver chip for the meter.
Posted on Apr 05, 2017
5 Related Answers
Anonymous
  • 236 Answers
SOURCE: loss of one channel to speaker
when you say switching input wires you mean your source? that you switch it? you only have switch problem, it is mechanical type swutch need to clean only, if still possible. i dont know if you can find replacement.
Posted on Mar 25, 2008
Anonymous
  • 185 Answers
SOURCE: QSC 2450 Power amplifier
i have a pyle pro 1000 watt max 2 channel mono and 2 channel stereo and when i get that thing loud the little red light cums on basically what i mean is that the amp on channel one is cooked i myself i wouldn't even use it y cause more damage
Posted on Apr 07, 2008
robotek
Graeme Ross
  • 1512 Answers
SOURCE: Question on BB2125 2 Channel Amp
Hi jgoudie
It is a signal sensing turn on unit, so will not turn on until you have supplied signal to it. Plug it into a signal source and see what it does. But unfortunately, in my experience the protection light coming on means there is a fault in the amp.
You can download the user manual for the amp from here. Click downloads in the middle of the page:)
regards
robotek
Posted on Aug 19, 2008
HalfmoonUSA
  • 145 Answers
SOURCE: AC & Rear wiper switch button indicator lights blink
The procedure for re-setting the HVAC control panel on a 1998 Dodge Grand Caravan follows:
With ignition on but not running
1. turn knob to air vents
2. turn fan knob to ON
3. temperature setting on COLD (2X) {I have dual temp controls}
4. hold top(rear wiper) and bottom (rear wiper with wash) buttons pressing down together until all the buttons cycle through (this will require 1 to 2 minutes of continuous pressing)
I learned this from a very helpful local Dodge service adviser
Posted on May 15, 2009
smarthome2
Frank Fulton
  • 1114 Answers
SOURCE: NAD 302 PHONO STAGE
Reverse your RCA input around and see if the problem follows, this will determine if the problem is in the turntable output signal or the preampsection of your amp. If it stays on the same channel, slightly move the RCA that's dropping out signal around. If the signal cuts in and out, you know it's just a weak solder joint on the input rca of the amp. If it does not change, your problem is deeper. Chances are it's a "cold solder joint" on the input section of the amp and would only be a labor type repair and no parts involved. That can be a double edged sword as well depending on how long it takes to find it. If you have to have it serviced, find a local shop that's been around a while, they are likely to be a little more insightful as to the exact problem quicker. Hope this helps
Posted on Jun 26, 2009
How do I take a picture?
use complete sentences please when asking a question in the form of a category
Apr 22, 2015 | Technical Pro RX-B113 Integrated...
Problem with amplifier equalizer HITRON
You would be better off replacing the unit
May 22, 2013 | Computers & Internet
I have a vintage Sansui qrx5500, everything lights up, the meters show that the preamp is processing a signal but there is no sound, not even through headphones
The problem is something to do with the power amp board. You need to determine if it is going power to it, from the power supply section. If it is it would indicate the main power amp has gone. Does it have an IC power amp? If it does then it's gone! Otherwise I am puzzzelled why both channels are down on a device with two seperate transistors stages.
Jan 13, 2013 | Audio Players & Recorders
Hi, The right channel of my quad 909 amplifier doesn't work anymore. I replaced the fuse (FS2) of the channel which was blown. Unfortunately, it blew again after replacement. What is causing this and...
These are relatively simple designed units that produce clear sound. The output transistors are the most likely parts that are defective. Usually when those short, other parts in the driver circuit go as well. While simple for those with experience, it is difficult to state what exact parts will need to be replaced without seeing the actual unit and taking internal measurements. If you have no experience with audio repair, please seek professional assistance. It is easy to cause further damage if improper repairs are attempted.
In this case, the parts cost is likely to be in the $50 range.
Dan
May 12, 2011 | Quad 909 STEREO POWER AMPLIFIER Amplifier
Marantz SR 4003, Cables in right place.PEAK light on?Help!
Disconnect your speaker wires at the receiver,then test if it does not "peak" the receiver is fine and you need to check each speaker wire. re-connect one speaker at a time and test until it peaks. then disconnect at speaker and test again. if it peaks, it's a bad wire, if it does not, check the speaker, meter it for a short. If you still need help, post a comment and I can help you some more.
Aug 08, 2009 | Audio Players & Recorders
Unbalanced LEDs> amplification problem, or mere graphic drop out?
This could be a defect in the metering circuit. In order to verify this, you should measure the output externally. Get that external measurement and post the results here. We'll continue from there.
Dan
Apr 12, 2009 | Yamaha DSP-AX1 10-Channel Amplifier
Ma audio hk 4000d
you have definately blown a output channel, or power supply. Send it in for warranty.
Jan 09, 2009 | MA Audio HK4000D Car Audio Amplifier
Fact or fiction. Are Rockford P10002 amps overrated
The efficiency of an amplifier has nothing to do with the RMS rating of the amplifier. It is true that no amplifiers are 100% efficient. The efficiency of the amplifier is calculated by how much power output it has compared to how much power it actually uses to create that output power. The RMS rating is just a measurement of the output power with no consideration of the amount of power that is needed to create that output power. Most of the high-end amplifiers are properly rated. If you see power ratings that refer to peak power, it is a little misleading. The true power of an amplifier is the RMS rating. It stands for "root means squared" but is the effective power that you hear, often referred to as the true power. It is calculated by taking the peak power and multiplying it by .707, which is always less than the peak power. When the rating of an amplifier is calculated they use a sine wave at a single frequency and it has a positive peak and a negative peak. If the power is calculated using both peaks it is called the "peak to peak" power rating. When it is calculated using only one peak it is called the "peak" power rating.
The big "con" in all of this happens when manufacturers use the "peak" power ratings instead of the "RMS" power ratings because it makes people think that the amplifier has more power when it really doesn't. Most people have no idea there is a difference in the "peak" power or the "RMS" power. It is a deceptive way of making people think that they are getting a more powerful amplifier. But none of this is related to the efficiency of the amplifier. It is theoretically impossible to make anything electronic that is 100% efficient. It always takes more power on the input than it does for the output power of anything.
I hope this answered your question, if you have any other questions feel free to ask them just by posting a response on this thread, and remember, you get what you pay for. The best amplifiers cost more for one reason, they are better. I am a big fan of Phoenix Gold amplifiers.
Dave
Sep 24, 2008 | Rockford Fosgate P10002 Car Audio...
Kac 8452
The amp probably has shorted output transistors. You'll need an ohm meter to check them. If you're new to electronic repair and want to try to troubleshoot/repair the amp yourself, read the following page and then post any questions you have.
Amplifier Repair Primer
Apr 27, 2008 | Power Acoustik LT-980/2 Car Audio...
165 people viewed this question
Ekse
 Grubhead
Grubhead
