Question about RCA CC-432 Camcorder
Set time RCA AutoShot 72X Digital Zoom VHS recorder
2 Related Answers
Anonymous
  • 320 Answers
SOURCE: need unit to put tape into, to play in vcr
What you need is a VHS C adaptor. I did a Google search and found at least 10 sites selling them. Rather than cut and paste, I suggest you go to Google and type in "VHS C Adaptor".
Posted on Oct 29, 2008
techman007
Lavell Turner
  • 1112 Answers
SOURCE: camcorder won't record
Check the tape and make sure the record tab is still on the tape and has not been removed. If the record tab has been removed then use a new tape for recording as the unit will not record. This tap is usually on the lower left end of the back of the tape. When the tap is present it closes a record mode switch letting the system know the tape is able to bv recorded on..
Posted on Dec 27, 2009
Where can I buy a battery charger for my rca autoshot
easy, type in the name in a search engine and you can find it that way
I’m happy to assist further over the phone at https://www.6ya.com/expert/josh_8f8ad0a8f7e0e6d3
Oct 22, 2014 | RCA Autoshot Cc4352 3 Inch Lcd Color...
CLASSIC RCA AUTOSHOT VHS CAMCORDER.(DSP3) PROBLEMS
The vhs camcorder has very complex mechanics and hold many traps for the inexperienced.
I suggest you begin by obtaining a standard vhs recorder and remove the cover to expose the interior and then study it. You will find the engineering and interior geography of your camcorder similar.
The round shiny barrel-shaped thing contains the record and playback video heads and the sound head is separate and looks like a larger version of what can be seen in a standard audio cassette recorder.
The interior must be extremely clean, the drive belts in good condition and the clutches and rubber rollers also in good order.
Nov 16, 2017 | RCA CC6151 Camcorder
Can this camera become a webcam and how
Yes, but only with the yellow (video) and white (mono audio) rca plug cable (to mini USB) that came with the camera. This plugs the camera into a composite input (yellow) found on older video cards, VHS recorders, DVD players and TVs. There is no software switch to tell the Lumix what to do when it's connected to a PC by the USB cable; it just assumes you want to transfer files. Unlike USB audio recorders (Zoom H4) which give you the choice at plug-in, audio interface or disk drive?
Feb 01, 2010 | Panasonic Lumix DMC-FS5 Digital Camera
Quazar Model VHQ520/VHQ540 cannot record after inst Digital Conv
You need to set the vcr to channel 3 or 4 (whatever channel the digital converter box is set to broadcast on) to record a program. The digital converter box has to be set to the channel you want to record the show from.
Apr 09, 2009 | Quasar VHQ400 VHS VCR
Need unit to put tape into, to play in vcr
Oct 29, 2008 | RCA CC6263 Camcorder
Recording from the Mini DV to VHS Tape
Mini dv is a digital recording and VHS is analogue so they are incompatible. Does your camera have an analogue output? That is a lead that ends with something like RCA plugs or a Scart plug. Then you can feed the signal into a VHS recorder.
Aug 23, 2008 | Canon ZR45MC Mini DV Digital Camcorder
Video camera classes
Check with your local community college
Aug 03, 2017 | Canon ES10V Camcorder
Record from a VHS player
This is an easy one. It took me a while to figure it out too. You are on the right track but you need to use the remote control. You will go from record/pause to record and of course you have to use the mini to triple RCA cable that comes with the camera. I can't remember if there is an internal setting in the menu that needs to happen but I don't think so.
Videoteacher
Jan 07, 2008 | Canon ZR70MC Mini DV Digital Camcorder
Recording
you have to play the vhs before hitting the record button or the lyra will pick up no signal i had the same problem recording my dvds
Aug 18, 2006 | RCA Lyra RD2780 Digital Media Player
RCA CC-432 Camcorder Logo
Top RCA Video Cameras Experts
Lawrence Oravetz
ADMIN Canada
ADMIN Canada
Are you a RCA Video Camera Expert? Answer questions, earn points and help others
