Washing Machines Logo
Caroline Adams Posted on Mar 22, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi my washing machine saying fault 49 on it model WL80T65C
Showing fault 49 what is it
  • Caroline Adams Mar 22, 2012
    My machine justs beep when i turn on and displays fault 49 its aaqua smart from fisher & Paykel any one know how to fix it
Tony Crow
Level 3:
Master:
  • Master 578 Answers
  • Posted on Mar 22, 2012
Tony Crow
Master
Level 3:
Master:
Answers
578
Questions
Helped
143275
Points
1638
Prob the capacitor faulty on motor , or start up windings on motor burnt out ,
5 Related Answers
Anonymous
  • 69 Answers
  • Posted on Mar 09, 2010
SOURCE: WASHING MACHINE WONT START UP AND DISPLAY FAULT
Fault 49 indicates Out of Balance fault- usually faulty microswitch. To access- disconnect from power, remove two screws at top rear to remove control panel. You will see large brown control board. Disconnect all wiring connections, taking note where they came from (they are keyed to only fit in correct slots, but is best to note positions anyway). Remove brown control board (held in by either one screw, or clip on right hand side) Underneath control board you will see a small microswitch with two wires on it- this is the Out of balance microswitch. Often the switch will be corroded, or the little button is stuck in. Replace microswitch- they are available from any good appliance parts shop, and you'll be back in business!! If in any doubt as to doing this yourself, call in the experts, as it is an easy repair for a tech, and you don't want to make an easy repair turn into something more expensive!!
A
Anonymous
  • Posted on Apr 08, 2008
SOURCE: washing machine fault
Kenmore Elite, spin cycle will not wring out the clothes because the tub is not spinning, you can hear it working though. Please show a diagram. Thank you.
barkencoa
Barry Coates
  • 3463 Answers
  • Posted on May 30, 2009
SOURCE: hotpoint ultima super silent w f 840 shows fault 03
Code f03 means wash thermistor open circuit, this is normally part of the heating circuit, suggest you test heater and thermistos located in the end of the heater, and replace if necesscary. If heater o/k , then could be bad connection to control module, or broken wire, if still no joy, then call Hotpoint.
Please rate my solution.
Thanks.
Anonymous
  • 27 Answers
  • Posted on Sep 23, 2008
SOURCE: Fisher and Paykel Intuitive Eco Washing Machine
The drain pump is overheating. I suggest you do not try to use the machine until you replace the pump unit, failure to stop using the machine will result in the pump short circuiting and destroying the main control board!. Please go buy a new pump and fit it.
Anonymous
  • 5 Answers
  • Posted on Sep 17, 2009
SOURCE: hotpoint ultima washing machine is showing a fault
F 05 normally means there is a blockage or a fault with the pressure sensor. The common place for blockage is in the black pipe from the drum to the pump as it has a filter in here and clogs up. remove the pipe and clean the filter out and remove gunk from the pressure sensor on the side of the pipe as well. If that does not fix things the pressure switch could be faulty itself
Error 27 Fisher and Paykel
27. (00011011) Fabric Softener Valve Fault
The Motor Control Module has measured a voltage from the valve diagnostic circuit that
indicates the fabric softener valve (with Yellow Clip) is faulty. The most likely cause is that
the valve harness has not been connected correctly or the valve is open circuit. See fault
code 49 for service procedure.
Error code 49 f&p aqua smart wl80t65c
49 is a cold water valve fault. test the valve for voltage while filling, it should be recieving 24V. if not, the problem lies with the motor controller.
Error code 49 wl80t65c
cold water valve fault. often caused by the motor controller failing. test valve during fill for 24V recieved. if not, motor controller needs replacing.
Need a service, fault 49 ???????
cold valve fault. check the water supply, check the valves. otherwise it's the motor controller. replace parts as necessary.
Fisher paykel aquasmart fault 49
Fault code 49 is water valves, But the Aqua-Smart board is outputting the wrong code here, The Smart pump has blown the water valves fuse, A common thing in Aqua-Smart Machines.
The Smart pump has jammed with lint and caused over current to the board and taken out parts on the board that drive the pump.
Best to get a new/recondition board for your machine.
1helpful
Fisher paykel aqua smart fault 49
Fisher and paykel toploader washing machine fault 49 water valves all show 60 ohms next step?
Fault code 49 is water valves, But the Aqua-Smart board is outputting the wrong code here, The Smart pump has blown the water valves fuse on it's overload, A common thing in Aqua-Smart Machines i always keep seeing,
Error codes 49 and 245
Fault code 49 is water valves - usually, the stop working when the rubber diaphagm inside gets hard, so a resistance only test is not conclusive (only tells us the solenoid is OK).
- Do a cold fill and a hot fill (briefly) to check for strong water flow on both.
- Regarding code 245, does water pump out strongly?
- One more thought, because these codes are both related to the water level in the machine, remove the level sensor hose at the controller end and blow into it to clear any blockage.
Top Washing Machines Experts
john h
