When you press the power button you hear clicking but no picture
SOURCE: Toshiba 52hm84 DLP buzzing sound after replace bulb?? no pic
You have bad capacitors in the power supply that took out the regulator, or the ballast circuit is defective. Not really a repair for the novice. Good Luck
SOURCE: Akai PT50DL24 50 in DLP Rear Projection TV-NO PIC OR SOUND
check for popped or raised tops on caps in power supply. also try unplugging set for 5 minutes and resetting it. How about does your color wheel spin up? if your color wheel don't startup then your tv will also shut down. also check all fans they all should be running at turn on. if all fails i would say its your light engine.
SOURCE: Samsung 50" DLP - Lamp Light Blinking after bulb replacement
Listen closely. The tv should make a high pitch whine as it turns on. If it does wait and see if it tries this a few times. If yes then check the bulb, I have seen cases where the lamp shoves the power connector back into the set. If the tv starts with a grown or heavy vibration noise, then your color wheel may have broken and needs replaced.
SOURCE: My LG DLP RU-52SZ51D rear projection TV doesnt turn on.
See if Lamp Fan is running it can be defective and if Fan is OK it will be Ballast Board, Call Encompass Parts 1-800-638-3328
