Question about Texas Instruments TI-84 Plus Calculator
Ti 84 plus screen faded away
I dropped my calculated because I was mad at my brother for deleting all my Y= equations while pushing random buttons. Then I worked with it for a couple of seconds trying to move on to my next math problem and the screen faded away, i put new batteries into it but the screen stayed the same what do I do before my mom buys me another and is mad at me for life?
Posted by Katie W on
Stevan Milanovic
    Sergeant:
  • Texas Instru... Expert
  • 267 Answers
If you cannot see anything on the screen, you may need to adjust the graphing TI 84 calculator contrast :
1. To darken the screen, press and release 2nd key, and then press and hold up-arrow key until the display is sufficiently dark.
2. To lighten the screen, press and release 2nd key, and then press and hold Down-arrow key until the display is sufficiently light.
Posted on Mar 22, 2012
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible.
5 Related Answers
k24674
  • 8091 Answers
SOURCE: my TI-83 plus calculator doesn't work
As battery gets drained, the screen contrast dims. But when you change batteries, some times the contrast is reset to some low value and the screen appears dead: it is so light that you do not see anything, and you think the calculator is malfunctioning. This is the most frequent reason users think the calculator refuses to turn ON. And I hope that is the case now.
To correct that, you must increase screen contrast: draken the screen a bit. To do so
  1. press [2nd] key and release it.
  2. Press the Up arrow and HOLD pressure.
  3. Keep pressing the arrow key until screen is dark enough.
If that solve your problem that is good, rate the post accordingly.. If that does not, do not get irate and berate the post. Post a comment here describing what you did and what message (if any) calculator returned, and I will give you further diagnostic steps.
Posted on Jan 21, 2010
Anonymous
  • 21 Answers
SOURCE: TI-84 Plus Calculator will not turn on, says ram is cleared
Thats because the OS is corrupt. Follow the manual and reload the OS, try the 2.43 OS
Posted on Mar 02, 2009
Anonymous
SOURCE: My TI-84 Plus always turns off randomly
My calculator does the same thing. Somebody help us!
Posted on May 02, 2008
Anonymous
SOURCE: how to restore applications on TI-84 Plus Calculator
Go onto www.education.ti.com, find the downloads column, and click on apps and operating systems. Then you can click on the different lists and find out which apps you accidentally deleted. You do this by (after clicking on it) looking under the "Pre-Loaded On" column. If you find the name of your calculator there, this is one application that was deleted. Hope this helps!
Posted on Aug 05, 2008
k24674
  • 8091 Answers
SOURCE: TI-84 Plus LCD display broken. Is replacement available?
Contact [email protected] or www.ti.com/calc .
Hope it helps
Posted on Oct 25, 2009
How do i do systems of linear equations on my ti-84 plus
You can download the Application Plysmlt2 from education.ti.com and use TIConnect to transfer it to the calculator.
Here are three screen captures to show you what it can do.
Hope it answers your question.
Dec 09, 2011 | Texas Instruments TI-84 Plus Calculator
2c + 6 + 7c = 8
To solve this with a ti-84 press [math] and select solve from the menu. This will open the equation solver. Type in your equation
(Note: you may need to put it in the form with 0=, So the equation would be 0 = 2c + 6 +7c - 8 ). Then press
enter or arrow down button.
Mar 30, 2011 | Texas Instruments TI-84 Plus Calculator
How do you enter the "plus or minus" sign into the y= of a ti-84
The calculator cannot handle "plus or minus" in the same equation. If you need both, enter two equations into y=, one for plus and the other for minus.
Feb 25, 2011 | Texas Instruments TI-84 Plus Calculator
My TI 84 plus silver: whenever I push the graph button the message ERR: Syntax 1:quit 2: goto appear on screen please help
Press the Y= button.
There are several possibilities:
1) Scroll through all equations, Y1 through Y9 and Y0. Make sure they are cleared.
2) The equation you typed in is not entered correctly.
3) Make sure Plot 1, Plot 2, and Plot 3 are NOT highlighted.
Feb 01, 2011 | Texas Instruments TI-84 Plus Calculator
I have a TI 84 and i can't change the value of x to use in simple equations and need to know how.
Example: I would like to set x equal to 5. The screen should look like this:
5 -> x
This is accomplished by pressing the STO key (the button above the ON button).
Jan 21, 2011 | Texas Instruments TI-84 Plus Calculator
Screen displays small horizontal line when powered on that quickly fades away. Have changed batteries. When I do a reset (take one battery out, push delete while putting it back), the screen displays...
Here is what the Texas Instruments Knowledge Base has to say about your question.
I hope it helps.
Reinstalling the OS fot the TI84Plus
Howdo I correct the Error Waiting...Please Install Calculator SoftwareNowmessage on my TI-83 Plus family or TI-84 Plus family calculator?
If an operating system (OS) update fails or is interrupted, the calculator will be in an inoperable state with the message Waiting...Please install calculator software now.Themost common cause of a transfer being interrupted is updatingthe operating system on a calculator with low batteries. Users will needtouse the TI Connectivity cable and the TI Connect to sendthe operating system to the calculator. Make sure to have thelatest version of TI Connect installed on the computer.
In order to install the software please follow these steps:
1. Connect the TI Connectivity cable between the computer and the calculator.
2. Click on Start >> Programs >> TI Tools >> TI Connect >> TI OSDownloader
3. Follow the on-screen directions to reinstall the calculator's OS.
If themessage "Error! Press any key to turn unit off. Then turn unit back on."appears on the graphing calculator, quickly, remove one battery from thecalculator and reinstall it while the transfer is taking place.
Oct 26, 2009 | Texas Instruments TI-83 Plus Calculator
Stuck on a black screen
You darkened the screen. The solution is to lighten it.
Turn the calculator on. Press and release the 2ND key. Press and hold the down-arrow key for a few seconds.
Sep 09, 2009 | Texas Instruments TI-84 Plus Calculator
Deleted y column in TABLE
I do not think that you can DELETE it, you probably just cleared the equation, just put another equation into Y=, and it will work.
otherwise, if you don't have any programs you need or so... just press 2nd +
Scroll down to reset, and press clear RAM
May 26, 2009 | Texas Instruments TI-84 Plus Silver...
Entering inequalities into TI-84 to graph
I think you should get a Texas Instruments calculator and push the 'y=' button then put the equation like '2x+4' in the y1 area. You can put the X by using the variable botton. I hope my english makes sense I am not a native speaker.
Jan 19, 2008 | Texas Instruments TI-84 Plus Calculator
Texas Instruments TI-84 Plus Calculator Logo
2,076 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Paul Bade
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
