Question about Canon Elura 65 Mini DV Digital Camcorder
NO POWER WILL NOT TURN ON, BATTRY IS GOOD
Posted by yorki838 on
What cause battry to die over night?
If test light is a 12 volt light tester AND ILLUMINATES BRIGHT it shows that a component is actively trying to complete a circuit and yes drawing power causing a drain on your battery, now if test light illuminates low, possibility could just be ecm memory or antitheft system active . either way this test should only be done with a 12 volt test light as if you use a 5 volt (computer friendly) tester , false light will have you chasing a ghost. trust me. that trick helps by checking for parasitic draws a 12 volt tester does not illuminate when keep alive memory voltages are present . those voltages are not enough to drain over night. good luck
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_9ddabbbc483e2add
Nov 28, 2017 | GMC Cars & Trucks
LAPTOP WILL NOT START
check mains lead and fuse pluse battry,try starting up with out the battry just the mains.
Apr 16, 2014 | Samsung R Computers & Internet
Phone full battery but wont turn back on
may be battry is outdated or extra fully charged thats why sometimes it react like this or the size also bigger than normal battry so try new battry or check the PIN which is connected to battry when u put battry in mobile...thank you
Nov 03, 2013 | Samsung Galaxy Pocket
I have a waverunner 1200 xl limeted 1999 ther is no power wont turn over
There may be some fuses or power relays either behind the dash or near the battery compartment. One of those might be bad.
Sep 12, 2012 | Motorcycles
Dell latitude e6400 laptop bios override password needed
u can easilyn remove the bios password by removing cmos battry for abt 3 to 5 mins and in a laptop the laptop battry itself cointains cmos battry so u just need to take out battry and then switch ont the laptop without battry then insert the battry and switch it on again good luck
Jul 09, 2012 | Dell Latitude E6400 Laptop
I have a 2002 chevy impala i have a problm with my battery keeps die but i had it checked and it was good and the aulternater was good to what can it be
Remove your boot light & glovebox light. The battry is probably being drained by something you can't see. If no fix have key off, remove battry lead & put amp meter between. This will tell you if something is draining power
Jun 27, 2012 | Cars & Trucks
I have a 96 s10 blazer with a 4.3 starts hard idles rough wants to stall has misfire and when I turn on the blinker the battery gauge moves with it and when in park if I Rev the motor the speedometer and...
Have you checked the voltage at the batry when running? Sounds like alternator is not working properly. The battry is only used for starting, once started the alternator runs all the accesories & charges the battry. If not chargeing the vehicle will **** battry power. You may have a good battry surface voltage but a bad battry. The battry should be load tested as well.
Jun 24, 2012 | Cars & Trucks
I have a Compaq Presario R3000 with Windows XP OS. Until recently it had been working fine. Suddenly, the power went off while still connected to the AC Supply and the Laptop just went off. The battery...
1. Remove battery from the laptop. 2. Unplug the power cord from the computer. 3. Let the computer sit for a few min. 4. Leave battery out. 5. Connect power adapter to computer 6. Push power button to turn computer on. 7. If computer powers on shut down again, and put battery back in. 8. Push power button to turn computer back on (at this point battery and power adapter should be connected to the computer)
If computer powers on with power adapter with the battery out. You are having a battery issue. You would want to look into replacing the battery. If computer does not power on with just the power adapter. You are most likely having a power issue. Depending on how old the laptop is. You will either want to contact the manufacturer. Or take the computer to a computer repair shop, or consider replacing the laptop.
May 31, 2011 | Compaq Presario R3000 Notebook
When i put power to it i dosent turn on or the led light dosent come on
do you have the remote power wire hooked up next to the battry wire ,have you checked the fuse and do you have a good ground
Feb 14, 2011 | Rockford Fosgate Power 600.5 Car Audio...
Canon Elura 65 Mini DV Digital Camcorder Logo
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
