Question about Haier Washing Machines
Lost manual Hi I purchased Haier front loader model No: HWM 1260K in march 07 for my mother whom is 70yrs she has missed placed her manual, I have searched on the net to find another, and i am not having any success, can you please help me................. thanks for your time.....I know you's must have a lot more serious problems thanks again
Posted by kazabop on
1 Related Answer
rylee_smith
Rylee Smith
  • 8619 Answers
SOURCE: haier 1260k error message no 7
Hi
Err 7 is a motor error. You can reset the error by first unplugging the washer and then try and follow the given procedure to resolve error 7 --
  • Disconnect the machine from power supply and stop the water supply as well.
  • Access the back of the machine by pulling it under the counter.
  • Now you’ll be able to see Phillips screws at the back panel, remove them to access the small back plate.
  • Now from that opening you’ll be able to see motor and motor connector. Plug the connector back on to the motor if it is unplugged or loose. There is only way to fix it so you will not get wrong.
  • Now reconnect the machine with the water supply and plug it into the power supply.
  • Select only the quick wash cycle to test the machine.
After this if the error is not resolved then its an issue with the motor, and yu'll need to get it checked from a service tech.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Aug 05, 2009
I have an haier front loader washing machine hwm80-1403d and it is flashing an error3. What can I do have never used it.
Hi!
On Haier washers error 3 means "Detected washer temperature sensor error"
Check connections to washer temperature sensor.
Check temperature sensor.
Jan 07, 2017 | Haier Washing Machines
I lost my operating manual and would likd to download the instructions if possible
Here is a tip that tells you how to get a manual for most any Honeywell productonline...
Manual Honeywell How to Find Honeywell Manuals
heatman101
Nov 07, 2010 | Honeywell HWM-330 3 Gallon Humidifier
Haier 1260k error message no 7
Hi
Thanks
Rylee
Aug 05, 2009 | Haier XQG50-QF802 Front Load Washer
Error code 7
The error code 7 is in fact a motor error.
The motor that drives the spin cycle has become faulty. The only solution now is to get an engineer in to fix it or get it sent away to get repaired.
Sep 08, 2008 | Haier XQG50-11 Front Load Washer / Dryer
Cabrio he toploader leaking on towel/sheet cycle only
It is possible that the dispenser is leaking. It is typically the left front dispenser, you may notice a puddle on the left side. ???
Jan 09, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Manual
I lost my manual as well but found this link to a pdf version in case anyone else has the same problem finding it as we did. http://www.appliancefactoryparts.com/content/pdfs/113129.pdf
Dec 18, 2005 | Honeywell Warm Mist HWM-255 Humidifier
Washing Machines Logo
61 people viewed this question
Top Haier Washing Machines Experts
Marvin
Marvin
Sheldon Dedek
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
