Question about Motorola Mag One BPR40 Two Way Radio
Battery clips how do you replace the clips that hold the battery in place???it is located on the bottom of the radio.
Posted by mike r on
Van Allen
    Sergeant:
  • 278 Answers
You have to remove the circuit board from the case. There is a rod that holds the clip in. You have to remove a little rubber cover that keeps the rod from coming out.
You need the part number : PMDN4022AR
Posted on Jul 26, 2012
How do I change the battery on my Polo watch?
nnap back
2a 2b
? STEP 2 TOOLS NEEDED:
Prying tool, non-metal tweezers, small screwdriver, battery tester, cleaning cloth, screw holding tweezers, watch closing hand press, polishing cloth
Place the watch in the case holding vise. Clamp the watch in the case holding vise by opening the two halves of the block. Place the watch in the middle, and gently release or tighten the two halves so that they hold the watch firmly (2a).
If the watchband does not unbuckle or unclasp, separate the band by pressing down with the pointed tool to remove the spring-loaded pin that connects the band to the clasp or watch (2b).
3a 3b 3c
? STEP 3
Remove the back. Look for the groove between the round back and the watchcase (3a). Gently insert the case knife beneath the lip which is usually opposite the stem or the nine o'clock position. (3b).
Work the knife into the groove between the round back and the watchcase. Twist the tool to snap off back (3c).
4a 4b 4c
? STEP 4
Remove the batteries. IMPORTANT: Before removing batteries, be sure to note which side is up. You'll have to put the new batteries in exactly the same. In some watches, the batteries are held in by a small metal clip. If so, carefully follow these directions for removing them.
SPRING CLIP: Lift up one end of the metal clip with the fine point tweezers-it will come out. Then, remove the batteries (4a).
SCREW ON CLIP: Remove the screws with the small screwdriver (4b). Be careful not to lose them. Caution: Clip may spring out; maintain pressure or screw may be ejected.
PERMANENT CLIP: Lift the outside edge of the battery out of its compartment with the small screwdriver (4c).
5a ? STEP 5
Test the batteries. See the battery tester for operating instructions. IMPORTANT: If the watch has two batteries and only one tests "replace", replace both batteries. If both batteries test "good", there is some- thing wrong with the watch. Refer to your watchmaker.
? STEP 6
Locate replacement batteries. Read the number on the old battery. Find the same number in the Star Struck Cross Reference Guide (6a). Choose the corresponding battery listed in the Cross Reference Guide from the Star Struck battery assortment cabinet (6b).
? STEP 7
Clean the battery compartment. Check the battery compartment for dirt and remove it. If you find corrosion, refer to your watchmaker.
? STEP 8
Install new batteries. IMPORTANT: Be sure to test the new batteries before installing. For tester settings, follow manufacturer's instructions. Install the new Star Struck battery(s) with the same side up as the one(s) you replaced. Remember the watch won't work if the batteries are put in wrong.
SPRING CLIP: Place one end of the spring clip in place and push the other end into its slot (8a).
SCREW-ON CLIP: Place the clip over the new batter- ies. Hold the screw with the screw holding tweezers to start it in to the hole. Tighten the screw (8b).
? STEP 9
Close the watch. IMPORTANT: If there is a rubber sealing gasket in the back of the watch, make sure it is lined up properly before closing the back. Snap a metal adapter that is slightly smaller than the watch back into the upper jaw of the press. Place the support plate into the bottom of the press and fit a plastic ring adapter large enough to hold the watch into the support plate. Place the watch face down into the plastic ring adapter and press gently on handle until the watch snaps into place.
6a 6b
7a
9a
8a
8b
? STEP 10Clean the watch. Gently wipe the watch to remove any fingerprints or smudges.
? STEP 11Reset the watch. Reset the watch and make sure it is working. In analog watches, if there is no
second hand, observe the minute hand through a magnifying glass until you detect movement.
Sep 10, 2015 | U.S. Polo Assn Mens Rose Gold & Black...
Remove radio
Remove any media that may be in the radio.
Put your car in park, set the parking brake and remove the negative battery cable (the black cable) from your battery's terminal by loosening the bolt on the clamp, with an adjustable wrench.
Remove three Phillips screws spaced across the bottom of the radio's trim panel. This is a large panel on the dashboard that surrounds the radio and the instrument cluster. OBD365
Remove three Phillips screws from the top edge of the the trim panel.
Pull the trim panel off by pulling firmly towards you, starting in the center. This will release the clips holding the panel in place.
Remove two 3/8-inch bolts holding the radio in place.
Pull the radio away from the dash and unbolt the metal strap attached to the back. It's held in place by a 3/8-inch bolt.
Unplug the wiring plugs attached to the back of the radio by pulling them firmly away from the back of the radio chassis. Remove the radio from the car.
Foxwell NT630 AutoMaster Pro ABS Airbag Reset Tool
Sep 19, 2014 | 1997 Ford Explorer AWD
How do I replace the keyboard on a Gateway LT3119U?
Visit the Gateway support document website and locate the "User's Guide" section of the listings for your laptop model.
You should be able to locate either a "component replacement manual," or a document focusing specifically on replacement of the keyboard for that model (as different models of keyboards have slightly different methods of removing the keyboard.)
You may also wish to check the FAQ's in the support documents of your model, as they may also contain information on replacing the keyboard.
Power down your Gateway laptop and remove the battery.
This will not only ensure that you don't accidentally damage your laptop by powering it up while working on its components, but may also be necessary to reach the mounting screws for your laptop's keyboard.
Press the power button once after the battery has been removed to discharge any remaining electricity that the laptop may have stored.
Consult the support documents for your Gateway laptop model and find out where the keyboard mounting screws are located.
There will most likely be between two and five screws, depending on the specific model of laptop that you own.
You may be required to remove the keyboard bezel (the strip of plastic that runs along the top of the keyboard) in order to reach some or all of the screws; this can be done either by sliding the bezel off to the right of the laptop or by simply lifting it off once loosened (though you may need to use a coin or flat-head screwdriver to detach clips or pry the bezel out of its resting location.)
Remove the screws holding the keyboard in place.
The screws will either be located on the bottom of the laptop (under the space that the battery occupies) or beneath the keyboard bezel.
Put the screws in a safe place where they will not be lost, since you will need to use them to secure the new keyboard.
Lift the keyboard up from the bottom, detaching the keyboard connector and pulling the keyboard itself free from the Gateway laptop, then setting it aside.
You may need to once again use a coin or flat-head screwdriver in order to depress clips which might be holding the keyboard in place.)
Plug your new keyboard into the keyboard connector, then carefully place it back into the space previously occupied by your old keyboard.
If the keyboard is designed to be held in place by clips, press down with sufficient pressure to clip the keyboard into place.
Replace the screws that you had previously removed from the Gateway laptop.
Make sure that the screws are firmly in place both to ensure that the keyboard is secure and also to eliminate any potential problems with replacing the bezel or battery.
Reattach the bezel (if you removed it) and the laptop battery, making sure that all components have been reattached and are firmly secured.
Once the battery is back in place, press the power button to power up the Gateway laptop and give your operating system a chance to recognize the newly-installed keyboard.
hope this helps
http://www.youtube.com/watch?v=z7fs3nce2g4
watch the video
Oct 06, 2012 | Gateway LT3119u (LUWEW02001) Netbook
Mitsubishi Eclipse Spider Gt-S I cannot figure out how to get the fascia panel and face plate off of the radio to get to the numbers needed to retrieve the radio code. How do I take the panels OFF?
Hi
The stereo in the Eclipse can be removed with nothing more than a Phillips screwdriver
Disconnect the negative battery cable from your Eclipse's battery. Remove the two Phillips screws along the bottom of the radio/climate control trim panel. Lift up the bottom of the trim panel to unlock the lower retaining clips. Work your fingers around the sides of the panel to loosen the other clips and remove the panel. Remove the four Phillips screws holding the stereo in place. Slide the stereo out of the dashboard and disconnect the wiring harness and antenna cable from the back of the device.
Also check this link if it helps:-
http://www.ehow.com/how_5938157_remove-eclipse-car-radio.html
May 04, 2011 | Mitsubishi Car Audio & Video
T289 battery replacement. Does the clip have to come off the back before sliding down the U shaped black bottom?
No, but it might be handy to remove it. To remove it you would look at the front of the radio, and place a small screwdriver under the lip of the clip and gently pry up. However, you can remove the u-shaped bottom without removing the clip.
best regards.
Feb 01, 2011 | Motorola Talkabout T289 (14 Channels)...
How to remove the factory installed radio?
To remove the radio of your car, follow the process below:
  • Turn the vehicle off and disconnect the negative battery terminal cable from the car battery before working on the radio.
  • Take off the dash trim area around the car radio. You may need to use the flat head screwdriver to carefully pry the paneling and trim off. Some cars use plastic clips or screws to hold the dash trim in place. Locate any clips or screws and remove them.
  • Use the Phillips head screwdriver to unscrew each of the screws holding the car radio in place. Most car radios are held in place by four screws, one on each corner. After removing each screw, carefully slide out the entire car radio.
  • Disconnect the wiring harness, main power supply and ground wire from the back of the radio. You may also need to disconnect any antenna connections or speaker connections.
Take care and good luck
Oct 31, 2010 | 2002 Lincoln LS
How do you change the batteries? I've lost the instructions...
There's a clip centered at the bottom on the back of the radio. Push the clip down with your fingertip or a coin, then lift the battery cover up from the bottom of the radio to expose the batteries.
You didn't specify a model, so I can't give you a specific link, but you should be able to locate and download the operating manual for your radios here:
http://www.midlandradio.com/Two-Way-Owner-Manual
Bill B
May 29, 2010 | Midland Two Way Radio
Can't get the click and back off of my walkie talkies to change
I had problems removing mine also. 1st remove the clip. With the back of the radio facing you push down firmly with your thumb and slide it off. At 1st I didn't think mine removed but after some extra force I was able.
Dec 31, 2009 | Midland LXT310 2-Way Radio
Removing radio from 2008 f250
First you will have to remove the bezel around the radio. This bezel will also be from top to bottom. The bezel is snapped into the vehicle. Pry it out very carfully. Clips will be located at the top, middle, and bottom of bezel. Once snapped out, unplug harnesses so that you can easily work with radio and will help with not scrathing bezel. Once the bezel is out of the way, there will be four screws, 7mm or 9/32 use either socket size, that will be holding radio in place. Remove screws and then pull out radio. Use an aftermarket wire harness to make your installation easier. Install bracket and radio using screws removed and resnap bezel in place.
May 27, 2009 | 2008 Ford F 250 Super Duty 4WD
Back cover where that contains the batteries broke
Contact garmin at garmin.com, this is not an accessory, that you can buy anywhere, so send them an e-mail and see what they say.
Mar 31, 2009 | Garmin Rino 110 (14 Channels) 2-Way Radio
Motorola Mag One BPR40 Two Way Radio Logo
571 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Jane
Level 1 Expert
Muntejaya Ginting
Muntejaya Ginting
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
