My Uniden DXAI5588-2 cordless phone 5.8 GHz has two handsets but only one works. After the battery died on one of them, it won't work now even fully charged. I think it needs to be reset but I don't know how to do this.
SOURCE: 2 uniden cordless phones aren't working
I always tell people NOT to buy new batteries to try and fix their cordless phone. It seems to rarely solve the problem and you are usually better off just spending the money on a new phone. Unfortunately 5 years is a long time for cordless phones these days. There are so many brands, and so many thousands of models, it's impossible to keep track of them all.
I don't know if this helps, but perhaps the problem is using two or more phones. On a whim, I charged a Uniden EXP 970 that my daughter gave me a few years ago. Charged right up and it has been working for about two days. I didn't think it would charge at all but to have it actually work, I was amazed!! Will post if it quits anytime soon.
FYI I bought two phones from AT&T, each around $200 and neither of them worked after a week. I was not happy! These less expensive phones seem to do a much better job!
Jann
SOURCE: base not able to connect to handset.
I successfully reset Radio Shack (Uniden) 5561 handset by reconnecting the battery while holding the '*' and '#' key, then press the right upper soft key near the LCD window. The display will indicate "EEPROM/RAM cleared!!" and will return the handset to the factory default condition - looking for a base to register to.
This is possibly caused by the internet connection.
Try new ADSL filter.
You need one each per device.
SOURCE: No dial tone on handset
It may not be registed with the main unit. You may need to register the handset. With my uniden all i have to do is put it in the main base until it says what handset it is (it should be a number).
If you have any questions please dont hesitate to ask
1.Check that the base unit's AC adapter is plugged into the both the base unit and electrical outlet firmly.
2.Wipe the base unit's handset holder's connectors and the connectors on the bottom of the handset with a soft cloth/rag or pencil eraser to remove any loose dust and dirt from the metal connectors.
