To help you change the brightness and contrast settings from the LCD monitor, please follow the instructions mentioned below,
The control buttons are located at front panel of the monitor. The Brightness Button is used to select the Brightness/Contrast adjust functions. Press to switch functions or adjust settings.
To decrease the brightness or contrast press (-) button & to increase (+) as per your adjustment.
On your monitor there should be a dial or button that you can use to adjust the brightness to your satisfaction. The icon is usually represented by an image of the sun.
You cannot adjust the brightness with the key board. If the brightness
control on the monitor is not working. It may due the defect of
screen control on the flyback transformer. You have to replace the
flyback transformer (FBT)
open the monitor you will look big black part called EHT you will see the movable shaft on it rotate it by screw driver in active supply monitor see on screen suficient brightness and stop you will be satisfied
HelIo! right after computer inclusions on the monitor screen have a tablet with the message which disturbs to work. The message: brightness of the monitor of 100 %! A problem: how to clean from the screen this tablet so she prevents to read the information. I have not found adjustment in the menu of the monitor brightness. And what should be brightness: 100 % or another? have not found adjustment in the menu of the monitor brightness. And what should be brightness: 100 % or another?Thanks and sorry about my bad english. Afzal.
Due to it is new monitor the best way to solve problem is to take monitor back to seller and afterclaim it. Malfunction is inside monitor and you are not able to fix it. Good luck
I have/had same problem. I have ATI Radeon display adapter and in driver settings there was adjustment for brightness. I adjusted that to minimum and now the brightness is pretty good (still little bit too bright, monitor setting 0%).
Other succestions welcome...
