Question about Dell Streak 7 Tablet Android
How can I fix the charging port on my Dell Streak 7?
Posted by gobucs1266 on
  • 2 more comments
  • Arsh Karim
    Arsh Karim Jan 11, 2014
    watch this link to findout http://www.youtube.com/watch?v=WQQ4phOeH...
  • Arsh Karim
    Plz try to watch this link, may be helpfullhttp://www.youtube.com/watch?v=ilEUfWd3B...
  • Anonymous Mar 28, 2014
    the pins on the port are broke and I am trying to find a new port to replace it.
  • Anonymous Mar 31, 2014
    Where can I find a Dell streak 7 power port
Dave King
  • Dell Master
  • 1,606 Answers
Ok this is not a easy fix. The replacement port connectors are easy to get and cheap $4-$10. How ever they require that you are able to take apart the tablet unsolder the old port and then solder in the new one.
There are several places that will do this as a service but it ain't cheap. One place shows $299 for board repairs.
http://www.portatronics.com/index.php?cat=c295_Dell-Streak-7.html&XTCsid=vo7vc1f8r011l9e4p6e1bq34e3
If you search for "dell streak charging port repair service" you may find one closer or cheaper. It is possible that you can find a good board by searching for streak repair parts.
Make sure you know what replacement costs are for the unit. On some of these repairs you can come close to spending what you would for a new unit. So be careful about that.
Posted on Mar 22, 2012
Testimonial: "Thank you very much. Going to give it try"
  • Amanda Pugh Sep 18, 2012
    Where exactly do you find these replacement ports for a Dell Streak 7?? I have someone who can repair it but so far have had no luck whatsoever in finding the part.
Gareth Forbes
    New Friend:
I just tried this fix on my Dell Streak 5 too - with success. The battery wasn't charging at all and I thought I would have to chuck it. Used a small knife between the metal case of the jack and the plastic bit holding the pins and eased them apart, moving the plastic parts closer together. Carefully put the lead back in and back to full working order.
Posted on Aug 20, 2013
  • Pankaj
    Pankaj Jan 01, 2014
    this worked for me as well for Dell steak 5........thnx a lot guys
danielleathe
    New Friend:
Found this solution in the Dell Forum. Tried it, and it WORKED. Took all of 30 seconds. All you need is a push pin.
Posted by ScooterX replied on 13 Apr 2012 12:03 PMI was having the same problem. Plugging in my Streak 7, but it wasn't charging... Tested out the power supply, and it was good (plugged my cellphone cable into the brick - worked fine). After a bit of looking on the forums and not finding much useful, I went after what some of the postings hinted at... the connector.
So I looked closely at the plug-in on the Streak chassis and the cable. The cable plug has a single blade in the middle with power contact & probably data contacts that is surrounded by a metal shield.
The plug-in port on the streak is kind of a U-shaped dual-blade with corresponding contact facing to the middle... The design is for everything to dove-tail together when plugged in. The cable's power bladed in the middle, the Streak data-blades hugging up to the cable blade, then the metal shroud on the cable helps snug it all together.
On closer inspection, I found that the U-shaped blades in the streak had gotten pushed wider and the cable shroud was going to the inside and covering the contacts in the Streak.
I used a pushpin and tried to "close up the U" by gently moving the two blades in the streak towards each other to make room for the metal shroud to go around the outside. I also tried to open up the shroud a little bit on the cable to help things fit together nicely.
Following the adjustments, I was able to gently ease the plug into the streak and it promptly started charging!!! Issue resolved. Kept my Streak from being a chewtoy for the dog...
Good Luck!!
Disclaimer: Do this at your own risk. Be gentle with manipulating the blades. Make sure the cable is not plugged into the charger. Your mileage may vary.
Posted on Sep 16, 2012
How do i delete pictures on the dell streak 7
Grant,
You can drag the photo to the top of the screen and drop it in the waste basket. The waste basket doesn't always appear until you start dragging the photo.
So, until you try dragging you don't see where the basket appears.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Why wont my dell streak 7 turn on
Hello.
You can check if the battery had somehow got out of it's place.
Also it may be a software related issue, as a fix you can first try to plug it using the usb cable to your computer.
Hope it helps
Replace RCA 7in power port?
Contact any service technician. The set shlould be opened to replace it. It can be replaced. Gopakumar Gopalan Google
1helpful
Mac address of Dell Streak
Steve,
Below are steps to get the mac address on your Dell Streak.
From the home screen:
  1. Tap the Menu key
  2. Tap 'Settings'
  3. Scroll down and tap 'About Device'
  4. Tap 'Status'
The MAC is listed under 'Wi-Fi MAC Address'
How to find the IP address on your Streak:
  1. Tap the Menu key
  2. Tap 'Settings'
  3. Tap 'Wireless Controls'
  4. Tap 'Wi-Fi Settings'
At the bottom, under 'Wi-Fi Networks', tap the connection you are connected to and the IP address will be displayed on the next screen
Thank You,
Dell-Jesse L
My dell streak 7 wont charge
i can fix that pls.go to santy cellphone repair shop at greenhills shoping center
Dell streak wifi error
dell streak 7 v 3.2 wifi ploblem.i can't find wireless wave how to do that plz fix me
Dell Streak 7 Tablet screen configuration
it seems to have a reset button internally that might be worth a try. otherwise a full hard reset may be worth trying but that erases all data so backit up 1st. how to hard reset dell streak 7 hope that helps
2helpful
2answers
Hi, I'd like to get an UNLOCK CODE for my Dell Streak 7 . Please help, thank you very much really appreciated
Hello, first no one will give you free unlock code for your Dell Streak 7 except your network provider. You can ask directly to your network provider to get Dell Streak 7 Unlock Code, but you must prepare a good reason why you need that code otherwise you will get a charge aproximately $80 for that unlock code. The other way you can buy Dell unlock code from third party sites with cheaper cost rather than buy from official network provider. I hope my solution can solve your problem.
34helpful
4answers
My Dell Streak 7 Tablet will not charge. When the charger is plugged in, it does nothing. No light at all. When the power button is pressed, the front lights come on momentarily and then the charging light...
I can't charge my sell streak 7 (no orange and green color appear when plug in) moreover the unit can't turn on also.
I tyr hard rest also but no response at all
would you please suggest me how to do it
Dell Streak 7 Tablet Android Logo
Top Dell Tablets & eReaders Experts
ADMIN Canada
ADMIN Canada
ray gallant
Are you a Dell Tablet and eReader Expert? Answer questions, earn points and help others
