Question about UTStarcom Blitz Cell Phone
Como se hase un hard reset al ut starcom C1161 CDMA
3 Related Answers
Anonymous
  • 6 Answers
SOURCE: MY PHONE IS LoCKED AND I CANT REMEMBER THE UNLOCK CODE
the only way to change that password is to send it into verizon.
Posted on Mar 03, 2010
Anonymous
  • 25 Answers
SOURCE: i work for a towing company and found a ut starcom
Find an independent phone shop that does unlocking. Though check forst that the phone is legally yours now. Hope this helps!
Posted on Jul 04, 2009
Anonymous
  • 403 Answers
SOURCE: How to download music tunes, ringtones, and
You can download, save, rename, and assign ringtones directly to your phone when browsing the web. Here is how to download ringtones. 1. Press the Left Soft Key [Menu], then select the “WEB” spinning globe icon and press OK to select. 2. You will be directed to the WEB browser, where you will click on “New Hot Downloads” link. 3. From the “Realtones” or “Ringtones”, or the “What’s New” links, press “Select”, or OK. 4. Choose a ringtone or realtone you like by scrolling through the choices offered. You will be able to preview a small sample of each tone after you have clicked the “Preview” key on the title of the ringtone link, and you will be directed to a page describing your choice to preview. Choose the “Get” soft key. A downloading status page will appear. Next, you will be directed to a page that offers you to choose to play the ringtone or to purchase by using these soft keys. Press the “Play” soft key and you are allowed 2 usage rights to listen to the preview file. Choose the “Purchase” soft key to go back to purchase the ringtone. 5. Press OK on the “Buy” icon to purchase your ringtone. You will then be asked to confirm the purchase of this tone by selecting “Confirm”. Please note that you must have a balance in your account to cover the cost of content. You may add money by dialing “*99“ from your cell phone! 6. Press the Left Soft Key [Menu]. You will be directed to a description of your chosen tone. You will then be directed to the “Download Complete” status page. 7. Press the Right Soft Key [Menu] “Options” soft key. Here, you will choose to store the ringtone, or apply as a ringtone.
Hope this helps, let me know if I can help you with anything else.
JimmyC
Posted on Oct 06, 2009
Hola como configuro TENDA 300N como repetidor
https://translate.google.com/translate?sl=en&tl=es&js=y&prev=_t&hl=en&ie=UTF-8&u=http%3A%2F%2Fwww.microcenter.com%2Ftech_center%2Farticle%2F3006%2Fhow_to_set_up_a_tenda_router_as_a_repeater&edit-text= C?MO PARA: configura un enrutador Tenda como repetidor C?mo configurar un enrutador Tenda como repetidor Esta gu?a le muestra c?mo configurar un enrutador Tenda como repetidor. Estas instrucciones requieren que ya tenga un enrutador Tenda en funcionamiento. Si no tiene configurado su enrutador Tenda, consulte la documentaci?n de Tenda en la configuraci?n. Para el prop?sito de estas instrucciones, el enrutador que est? conectado al m?dem se identificar? como "Enrutador 1", y el segundo Enrutador se identificar? como "Enrutador 2" que se configurar? como el repetidor. Antes de comenzar, debe tener una conexi?n por cable a ambos enrutadores usando una computadora y cualquier puerto amarillo disponible.
  1. Conecte la computadora al enrutador 2 utilizando un cable Ethernet. Vaya de la computadora al puerto amarillo en el enrutador.
  2. Una vez conectado, abra su navegador web y escriba en la barra de direcciones "192.168.0.1". Presione Enter .
  3. Se le pedir? un nombre de usuario y contrase?a a menos que hayan sido cambiados de los valores predeterminados. El nombre de usuario y la contrase?a predeterminados son "admin" sin comillas.
  4. En SSID, cambie Tenda a Tenda 1 para identificarlo como enrutador 1.
    IMPORTANTE: Tome nota de qu? canal est? usando el enrutador. Ambos enrutadores necesitan usar el mismo canal. Puede cambiar el canal utilizando el men? desplegable y haciendo clic en Aplicar para guardar el cambio.
  5. Haga clic en la configuraci?n de WLAN del men? en el lado izquierdo. Las subcategor?as ser?n reveladas. Haga clic en Configuraci?n de WDS .
  6. En el men? de configuraci?n de WDS, seleccione Modo diferido en el men? desplegable. Haga clic en Aplicar .
  7. A continuaci?n, configure el enrutador existente que est? actualmente conectado al m?dem. Comience conectando la computadora al enrutador usando cualquier puerto amarillo disponible. Abra una nueva p?gina web y escriba "192.168.0.1" en la barra de direcciones.Use el t?rmino "admin" para el nombre de usuario y la contrase?a.
  8. Seleccione Configuraci?n de WLAN , luego Configuraci?n de WDS . Seleccione Repetidor en el men? desplegable.
  9. Elija Abrir escaneo . Se mostrar?n todos los enrutadores disponibles en su ?rea local. Seleccione el enrutador Tenda 1, luego haga clic en Aplicar . El enrutador se reiniciar?. Una vez que se reinicie, se mostrar? la direcci?n MAC del segundo enrutador.
Aug 17, 2018 | Televison & Video
Hola le acabo de cambiar los empaque a mi 300 crysler y cuando ya avía terminado le quice echar agua y empezó a liquiar agua x un ojito que está junto al termostato
Se me hace que el empaque se movio cuando tratatse de hacer el reparo. Ponle un poquito de empaque liquido en un lado de el empaque, ponlo y deja unos minutos (como 10 minutos) y pon las partes juntas y apriete los tornillos; pero no muy apretados. Deja como 20 minutos y aprietalos bien; al torque aprobado para la parte. Ten cudado de poner el termostato al lado que se debe poner. Perdon de mi deletreado, tengo mucho de no escribir en mi idoma.
Nov 22, 2014 | 2006 Chrysler 300
Vivo en Argentina y la camara que compre fue en U.S.A, no se prende la camara no tengo el cargador y le cargo en la computadora solo se prende y se apaga unos segundos la luz rojay luego se queda la luz...
Agrega una bateria nueva. Parece la que tiene no puede detener un cargo. quisa porque a durado mucho tiempo sin cargarla, se mojo, fue mal tratada, ya esta vieja, o la an cargado mucho. Los electronicos deberian ser desconectadas al momento que se llena el cargo. Si lo tienes conectado por mas tiempo le hase dano a la bateria. Hase que la vida de la bateria sea mas corta. Osea que no puede detener un cargo por el tiempo que deberia, y/o que no awante las recargadas que deberia. Como si deberia tener la capacidad te 300 recargadas nomas va a poder 200 o 100 depende en cuanto tiempo lo recargas despues que se llene la bateria.
Sep 06, 2011 | Jazz HDV-188 Camcorder
El carro enciende y trabaja bien en un principio despues de un tiempo se apaga el motor como que no llegara gasolina al motor, y no enciende mas hasta pasado un buen tiempo cuando se enfria el motor...
Hi!!
Por el a?o del vehiculo, casi puedo apostar que es la bomba de la gasolina. Cuando las bombas empiezan a fallar, trabajan por un rato, despues se calientan y dejan de trabajar, al poco tiempo, ya no trabajan para nada. Casi todas las tiendas de auto partes grandes como AutoZone y Checkers prestan herramienta. Consigue un Fuel Pump Pressure tester para que chequees la bomba de la gasolina. Ahi mismo te dicen cual es la presion que debe de tener. La presion se chequea abriendo la llave pero sin arrancar el vehiculo. Aqui esta un diagrama de como se connecta el probador.
Buena Suerte!!
Mar 16, 2011 | 1991 Honda Civic
COMO PUEDO QUITAR EL MODO DEMOSTRACION DE UN SONY BRAVIA 32BX3000
Entras al menú .... ajustes.... inicio automático. Ahí empieza una configuración inicial del TV y encontraras una seleccion de Modo entre Tienda y domestico. Seleccionas domestio y listo.
Un saludo...
Nov 02, 2010 | Sony Televison & Video
Falla nokia 5530 al responder o hacer llamadas
buen dia a mi me pasa igual y me dijeron una mala noticia. tiene un corto. me ddijeron q lo tienen q soldar y queda commo nuevo eso si, me cobran 500 pesos mex. pero ojo hay algunos sitios q te dicen q se la juegan que puede darse el caso q quede brickeado osea q se quede como labrillo o pisapapeles.sniff no tengo cash para arreglar el mio. waaaaa. eso se debe a q falla ese modelo de la nada. eso me explicaron.
Mar 04, 2010 | Nokia 5530 XpressMusic Smartphone
Que significa cuando enciende la luz OD/OFF es un sensor o es problema de trasmicion
es posible que es una problema de transmicion. es posible que es el interruptor de OD/OFF tambien. si Ud empuje el boton y la luz no se apgaue pero no aye otros problemas, creo que es probablament el interruptor.
Oct 09, 2009 | 1999 Ford Expedition
UTStarcom Blitz Cell Phone Logo
461 people viewed this question
Top UTStarcom Cell Phones Experts
Marvin
Marvin
L Vincent Testa
L Vincent Testa
Andrew Taylor
Andrew Taylor
Are you an UTStarcom Cell Phone Expert? Answer questions, earn points and help others
