Question about Logitech 250 Headset
No Jack Information Available when I connect my Logitech Stereo USB Headset 250 to Vista 64 bit OS
5 Related Answers
Anonymous
  • 6 Answers
SOURCE: I want to use my logitech usb 250
You will have to go in to Control Panel/Sounds and set the headset to be the default Audio device.
Posted on Apr 16, 2009
Anonymous
SOURCE: i cant get my logitech clearchat stereo headset to work for vista
I had the same problem until I noticed I was running Vista SP1. Search and download Vista SP2 and you will be good to go
Posted on Jul 13, 2009
Anonymous
  • 118 Answers
SOURCE: I need a vista driver
no you don't, you need drivers for the vista itself. try reinstall the sound card driver from the pc manufacturer's websight. try on another pc if it works there it is your vista computer. go with step one. if it does not work cal logitech.
Posted on Jul 18, 2009
Anonymous
  • 250 Answers
SOURCE: logitec250headset mic not working at all on this pc
Hi, Please uninstall any logitech software version present on your OS - Then please proceed to clean boot. ( http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=228 ) -> Unplug all the USB devices connected to the computer ( Less keyboard + mouse ) please use corded kbd+mouse if possible rather than a cordless device. -> Go to device manager -> Delete all the USB HOST CONTROLLER -- All of them -- -> The host controller might reinstall them itslef, let the computer handle the reinstallation -> If the computer does not reinstall the host controllers, trigger the detection using the DM function " Scan for new hardware " ( The computer with magnifier icon ) -> Once reinstalled, clean boot -> Reinstall the software if available and/or plug the hardware when needed. -> Should work.
This TB delete the usb ports " memory " means if a device as been previously flagged with error, it will redetect the device without the flag, unless there is some serious issue with the hardware/OS
If after this the issue persist, then I suggest you to call Logitech support to issue a replacement, hardware failures are covered by warranty terms
US/Canada support: http://www.logitech.com/en-us/contact
European support: http://www.logitech.com/en-gb/contact
Thanks and have a nice day ! J -
Posted on Jun 09, 2010
Anonymous
  • 250 Answers
SOURCE: i can't hear anything from my logitech headset
Hi Itsyen, go to start menu, control panel, sound. Then here go into the Tabs and select the Headset as Mic and Speakers. Apply, Done !
Thanks and have a nice day Julien
Posted on Aug 02, 2010
I have trouble connecting my headset to the mac. I don't know which wire goes to which plugin, and when I do connect it, no sound comes from my computer. And yes, I made sure the volume is up. May I...
GENERALLY... ONE jack goes to AUDIO or SPEAKER... the second goes to MIC INPUT or something similar...
SO ONLY ONEjack should give you AUDIO from your headset is your MIC !
THIS Link MAY help you! "I" had to convert it to English ! Thank you "Chrome". At least you can glean some HELP telephone numbers...
https://www.logitech.com/assets/46742/3/usb-headset-h390.pdf
Dec 23, 2017 | Logitech ClearChat Stereo Headset Headset
Tip
How to fix (workaround) Terrible sounding / input on win 7 64 bit with usb sound...
Terrible sounding / input on win 7 64 bit with usb sound drivers
looked for drivers from logitech - none besides setpoint - which didnt help
some fixed issue with a hub - tried - this didnt work either
workaround found
set output quality to lower than 44.1 16 bit - and sound clears right up.
thought i would let you know in case you came across the same thing <3
namaste
on Feb 04, 2014 | Logitech USB HEADSET H390
My girlfriend has a Logitech ClearChat Style headset. I recently gave her a Dell E6500 with onboard IDT High Def. Drivers and Windows Vista Business 64. The microphone rarely works (or properly...
Vista always has sound card problem.
I had too because with my headset (microphone) It works through your sound card
but it works well now after I installed it as below
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=US&swItem=ob-78911-1
ADI SoundMAX Integrated HD Audio Driver for Windows Vista
I am using Vista 32-bit, Logitech Clear Chat Style
Hope can help
Oct 08, 2009 | Logitech ClearChat Stereo Headset Headset
Logitec250headset mic not working at all on this pc
Aug 25, 2009 | Logitech 250 Headset
Can not load logitech quickcam commnect to vista
Is camera vista certified, not much works with Vista 64 bit it is at best incomplete; and few vendors even suppot it, do you have the latest USB 2.0, how about your drivers good luck with that
Jun 26, 2009 | Logitech Webcam
I need dirver Windows Vista 64 bits for Handycam TRV-740
This was taken from Sony's Website....
Driver information for Microsoft® Windows Vista® and Windows® XP
  • The drivers needed to connect most Sony® cameras and camcorders to a computer are already included in the Windows Vista and Windows XP operating systems. With these drivers, you should be able to connect and transfer files to a computer.
  • The USB streaming feature is not supported with the Windows Vista operating system.
  • Detailed Windows Vista compatibility information is available for Sony Cameras and Camcorders.
  • The Windows Vista Starter edition and Windows XP 64-bit operating systems are not supported.
So as you can see...the 64 bit OS is NOT supported.  The only luck you are going to have is either go to XP, Vista 32 bit...or see if there is a 3rd party driver someone made on the internet.  Try google....but I would have to say due to the complex nature of the drivers, it is highly unlikely that anyone has made a driver that is compatible.  It just has to do with how the 64 bit OS is made.  There might be a way to use 32 bit drivers, however you might run into some issues with processing and streaming.  To my knowledge of 64 bit systems, they are backwards compatible with 32 bit applications, so you can use wither 32 or 64 bit drivers....the only downside is by using 32 bit on a 64 bit machine, you are going to suffer a little bit of performance loss.  I hope this answers your questions.
Feb 22, 2009 | Sony Handycam DCR-TRV740 Digital Camcorder
Logitech Wave reciever not recognized
http://www.logitech.com/index.cfm/433/4677&cl=us,en?WT.ac=sc|downloads||dd
Just select OS 32 or 64 bit, etc.
Jan 17, 2009 | Logitech Cordless Desktop MX 3000...
Logitec drivers for vista
Logitech webcam drivers are available here. Select your webcam; select your OS (operating system- Vista); select 32 or 64 bit. DOWNLOAD.
Dec 15, 2008 | Logitech Webcam
Logitech USB Headset
its basic (USB Audio)
browse for the drivers.. or select driver to install
do it from device manager if you dont get a pop up
Apr 16, 2008 | Logitech ClearChat Stereo Headset Headset
Logitech 250 Headset Logo
Top Logitech Radio Communications Experts
Michael Thomas
Michael Thomas
Are you a Logitech Radio Communication Expert? Answer questions, earn points and help others
