The internal microphone is not working properly
Using
a microphone with computer
To use any microphone with your
computer you will need to enable it in control panel. The following
instructions are for Windows XP but are broadly similar for Vista
and Win7
Click START, CONTROL PANEL, SOUNDS
& AUDIO DEVICES
Click VOICE
Now click the VOLUME button in the
SOUND RECORDING BOX. Here you need to SELECT microphone as an input source for
recording (as opposed to un-checking mute in the playback
controls). If your webcam/ microphone is built in to the laptop there should also be a volume control called 'Internal MIC' - disable it by placing a check-mark in the mute box.
NOTE if microphone (or internal MIC) is not listed in the
2 sets of volume controls click OPTIONS, PROPERTIES on the tool-bar and
place a check against microphone in the list entitled
'show the following volume controls' and then click OK.
That should be it but it is possible you may also need to turn off the microphone in the software for your web-cam.
