I have all my wired connected correctly and all of them work. my amp powers up but doesn't make any sound. have tried the wires on a testlight and all of them work. please help
SOURCE: alpine cde-9843 . i hand it in and working for 3 days then no sound.
Try a CD lens cleaner[A disk with a little brush and a bottle of fluid. But be prepared for a new player - once the lasers goes its trash can time.
SOURCE: CDE-9845 is not turning on or doing anything.
The only way to know for sure is to see if it has voltage getting to it. You need a Voltage tester (DMM, testlight, etc...). There should be 12 volts on the yellow always and on the red wire when the Ignition/Accessory is on. If both are present then the radio probably got surged and will have to be replaced/repaired.
SOURCE: CDE-9852
probably the mode you are in, there is a mode for auxillary amplifier that disables the internal pa, in the aux amp mode you won't hear anything.
slonis
SOURCE: cde 9845 wire diagram
You can download a manual from here http://www.devicemanuals.com/guide/Car%20Audio/Alpine/Alpine-CDE-9845-43-41-Owner%27s-Manual-English-TmpneU9UYz.html
hope this helps.
caution
About Power supply wires (MRP-M1000 only)
• 21mm2 is the minimum power and ground cable size
that should be used to connect this amplifier. The
length of these cables should not exceed 1m to assure
safe operation.
• If the length of the power and ground cables exceed
1m, or if you connect more than one amplifier, a distribution
block should be used with 33mm2 or 53mm2
power and ground cables depending on the length
necessary. Ensure that you install a correctly-rated
in-line fuse on the power cable near the battery positive
post.
RMS Continuous Power (at 14.4 V, 20 - 200Hz)
• Per channel into 4 ohms (?1% THD+N)
MRP-M1000 ......................................... 600 W x 1
MRP-M500 ........................................... 300 W x 1
• Per channel into 2 ohms (?1% THD+N)
MRP-M1000 ....................................... 1000 W x 1
MRP-M500 ........................................... 500 W x 1
Total MAX Power
MRP-M1000 ............................................. 1900 W
MRP-M500 ............................................... 1100 W
S/N Ratio
• IHF A Weighted, Reference: rated power into
4 ohms .................................................... 100 dBA
Input Impedance
• RCA IN .................................................. 20k ohms
• SP IN .................................................... 40k ohms
Frequency Response (200Hz/ -3dB) ....... 20 - 200 Hz
Crossover Frequency .......... 50 - 200 Hz (-24dB/oct.)
Input Sensitivity (RCA IN) ............................ 0.2 - 4 V
Dimensions
• Width (Heat Sink/Footprint)
MRP-M1000
......... 320 mm (12 - 19/32")/380 mm (14 - 61/64")
MRP-M500
............... 210 mm (8 - 17/64")/270 mm (10 - 5/8")
• Height ..................................... 60 mm (2 - 23/64")
• Depth .................................... 242 mm (9 - 17/32")
Weight
MRP-M1000 ................................................ 4.2 kg
MRP-M500 .................................................. 2.7 k
ive had them in my old car which they worked, i also tested the RCA's from my old car which didnt change anything
on my CD player there is a SUBWOOFERS on/off, they are on and they are turned up. im not sure if its the CD player itself or the Subs
