SOURCE: dewalt compressor builds pressure then pops off at
would best guess that the pressure switch is stuck shut. if the pressure is going over 125psi, "and check with a good gauge" then the switch needs to be replaced.
SOURCE: Dewalt D55168 air compressor runs until 95 psi and
If you have no leaks the first thing I'd check is the ring and cylinder for wear. The cylinder wear is usually pretty obvious, but if you can see light around the piston ring it's bad. The replacement part number is N038785. Also check to make sure no valves on the valve plate part number A09819 are broken or bent.
