Woods Chest Freezer C1501W3 Logo
Anonymous Posted on Mar 20, 2012
Where can i get the light harness for the light inside of woods chest freezer, as the light wontwork and i put a new one in it ,no juice is going to switch
  • Anonymous Mar 24, 2012
    sorry all,, i found that the wire was broke behind the freezer, so i dont think it can be repaired, but freezer still works, i will rig up a light for it ... thank you ..
Anonymous
Level 3:
Brigadier General:
  • Master 6,468 Answers
  • Posted on Mar 24, 2012
Anonymous
Master
Level 3:
Brigadier General:
Answers
6468
Questions
0
Helped
2131705
Points
13357
Try sears parts online
4 Related Answers
Anonymous
  • 185 Answers
  • Posted on Mar 30, 2010
SOURCE: Both springs on lid broken. Lid won't stay up.
Whatever is on the shelf (parts that have not sold yet) is your best bet. Someone in the USA has to have em cause it hasnt been that long out of business.
here's one place to start ( i couldnt get thru)
AJ Madison
1416 38th Street
Brooklyn, NY 11218-3614
Phone: 800-570-3355
718-532-1800
Phone: 800-570-3355
718-532-1800 Fax: 800-570-7805 E-Mail: [email protected] Appliance
Parts Store:
800-378-5177
Appliance parts store:
1800- 378-5177
hope this helps
bobicehouse
Robert Moller
  • 1524 Answers
  • Posted on Jul 25, 2010
SOURCE: Hinds do not hold the chest freezer door open, need new ones
Call 1-800-673-1262 Give model number.
Anonymous
  • 31 Answers
  • Posted on Mar 03, 2011
SOURCE: My Woods Energy Star chest
17.77 Cubic feet
espressonist
espressonist
  • 1711 Answers
  • Posted on Aug 11, 2011
SOURCE: woods 221 chest freezer light
The problem is with lamp holder. You should remove the covel and reach for the lamp and remove it. First remove the power cable of freezer. Now try to bend the center back contact of the lamp holder which is actualy not making good contact with the lamps back contact point. You can use also a wire brush, or a glass paer to clean the contacts of bothe the holder and lamp. Also it may be nessesary to use a new lamp since sometime their contacts are melt a litle bit and they loose contact. In the worst case you may need a new lamp holder.
We have here a link with your model parts diagram, if the model differs then you make a research with correct model so you can have correct leyout.
Woods Freezer. Where is the off position on it please?
Question edited for clarity.
Question moved from Cars and Trucks category.
Freezers don't have controls INSIDE the freezer, as it is too cold for efficient operation. Chest freezers have them on the outside behind the grille where the compressor is. Upright freezers usually has electronic controls on the door. You give o clue as to what type you have or what model you have. You can easily turn it off by removing the wall plug!
Or you can find the manual. 'Off' on a thermostat is normally fully clockwise.
https://www.google.com/search?q=woods+freezer+manual
Green light on chest freezer flickering?
this just means the light is burning out (loosing its filament) it does not effect the operation of the freezer, it just is an indicator that you have power at the unit.
Aug 30, 2014 • Freezers
1helpful
IF THERE IS A HOLE INNSIDE THE FREEZER
The hole is for cleaning and draining. It has little effect on the temp.. Do you have to put bottles inside? To start with, liquids expand as they freeze and get hot. Anything below freezing is going to give you a problem. The colder, the sooner it will break the bottles.
3helpful
I have a woods chest style deep freeze and the lid is very cold on the outside, but the sides are room temperature and the freezer works fine. Why is the lid cold and how can I fix it
Yes, the freezer temperature means the lid gets very cold. Every time you open it some moisture condenses in the lid and the outside ambient also affects it. The insulation may be beginning to break down and the ice is forming inside. It is not a major problem however and many freezers go on for years with freezing lids!
1helpful
Lid of my chest deep freeze is cold on the outside
Normal phenomenon due to inside temperature and insulation properties of lid. Nothing to worry about unless you start getting bad condensation on the lid, when it's time for a new freezer!
1helpful
Order a freezer basket for a chest freezer
wc Woods is out of business however sears.com lista woods parts. Good luck.
Power Light On Woods Chest Freezer
blown globe or neon would not bother dont need it
Jul 18, 2010 • Freezers
Top Woods Freezers Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Woods Freezer Expert? Answer questions, earn points and help others
