Question about Kwikset Powerbolt/Electronic Deadbolt- Polished Brass
Reprogram remote keypad (kwickset model number 898)
2 Related Answers
Anonymous
  • 3 Answers
SOURCE: The back light is not working on our kwickset
When your door is locked, you must hit lock again before entering your code. After you hit lock the second time the LED back light will come on.
Posted on Jan 07, 2010
Coaltowner
  • 963 Answers
SOURCE: i have a kwikset deadbolt
I was searched but was unable to find any information on the model 898 keykess entry set.
I therefore suggest that you call Kwikset's Customer Service; I'm sure they can help you:
http://www.kwikset.com/Customer-Support/Contact-Us.aspx
Kwikset Corporation
Consumer Service
19701 DaVinci
Lake Forest, CA 92610
Kwikset Customer Service
Call: 1-800-327-LOCK (5625) Fax: 1-800-713-7080
Support Hours: Monday-Saturday
7:30am-4:00pm PST
Closed Sundays and Major Holidays
Posted on Mar 10, 2011
I need to know how to reprogram a remote control for a craftsmans garage door opener
Check this site.
http://www.buckeyedoors.com/tips/program-garage-door-remote.html
Dec 01, 2011 | Sears Craftsman LiftMaster Chamberlain...
HOW CAN YOU REPROGRAM BOTH REMOTES TO WORK? I HAD TROUBLE WITH THE ACTUAL DOOR, THAT GOT FIXED , BUT SOMEHOW OPENERS NEEDED REPROGRAMMING. WE CAN ONLY SEEM TO REPROGRAM ONE OR THE OTHER.
It sounds like you have a Security + opener and one of your remotes has reverted to the billion code technology. You will need to purchase a new remote with the same model number and then you will find that 2 of the remotes will program just fine. It will take trial and error to eliminate the bad remote. I suggest you remove the battery and discard the bad one.
May 27, 2010 | Sears Craftsman LiftMaster Chamberlain...
We can only get one remote to work when we reprogram the next one the first one stops working. the key pad is doing the same thing
You are probably not reprogramming the remote or keypad, but are using the remote to reprogram the receiver. But I can't get the instructions from the Chamberlain site without a model number. Here is their site:
http://help.chamberlain.com/help/en-us/programmingInstructions/
Jan 16, 2010 | Sears Craftsman LiftMaster Chamberlain...
How do I change the keypad number? we do not have
Press and immediately release the smart/learn button on the back of the motor unit and then walk over to the keypad and key in any 4 digit code you like and press enter.
Nov 14, 2009 | Sears Craftsman LiftMaster Chamberlain...
I have a 1/2 hp Sears Craftsman garage door opener dated 7/96 Canada I reprogrammed the remotes but I cannot reprogram the key pad. I push the square button and have someone punch in four numbers and hold...
If you have a wireless keypad you need to do just what you are doing except after pressing the last number you need to press enter. If your keypad is hard wired post back because the instructions are not the same.
Jul 08, 2009 | Sears Craftsman LiftMaster Chamberlain...
Remote and Keypads open neighbors door
Hold down learn button for 8 seconds. This clears the memory for all remotes. Then reprogam your remotes
Oct 31, 2007 | Sears Craftsman LiftMaster Chamberlain...
Kwikset Powerbolt/Electronic Deadbolt- Polished Brass Logo
284 people viewed this question
Top Kwikset Locks & Locksmithing Experts
Charles Tidwell
ray gallant
STEVE SPAM REMOVER
Are you a Kwikset Lock and Locksmithing Expert? Answer questions, earn points and help others
