Question about Hotpoint HSS25GFT 25.0 Cu. Ft. Side-by-Side Refrigerator with GE SmartWater Filtration, LightTouch
Wall between frig and freezer getting hot , fan not running ????
Posted by dan cruse on
Tony Crow
    Master:
  • 578 Answers
The fan is wired with a circuit board turn off and reserch parts on hotpoint ,
Posted on Mar 20, 2012
2 Related Answers
Anonymous
  • 3 Answers
SOURCE: FRIG AND FREEZER WON'T GET COLD AND FAN STAYS
possibly low of freon, make sure coils are lent free and area around compressor is vacuumed clean, unplug it first before cleaning please.
Posted on Apr 16, 2009
Anonymous
  • 5 Answers
SOURCE: freezer fan not running
Often times the defrost termination switch (which opens when it gets warm enough) will hold the fan off until it closes again when the freezer runs. It is possible that the switch is not closing, but be sure the freezer is getting cold enough for it to close.
You know the freezer is likely cold enough when you see frost covering the entire evaporator coil after a few hours of operation. A partial frost pattern could indicate low refrigerant, or a restriction of refrigerant.
Posted on May 29, 2009
2helpful
2answers
My refrigerator will not get cold, but the freezer work fine.
Are fans running? Any frost on inside back wall of freezer? Model #?
1helpful
Getting hot
This can be caused by the condenser running hot due to being dirty or the fan not running. See the link below for details on how to clean and check this.
Hot Rail between Freezer and Frig
Refrig compartment does not cool on my new Kemore Frig.
Check and make sure the fan in the freezer is running. if not possible bad fan. If fan is running, check to see if you have any ice built up on back freezer wall. Normally frost type ice. If so, you may possibly have a bad defrost bi-metal mounted in the freezer section. Next could be a defrost timer control. Model number usally will help more in getting it right.
1helpful
Compressor area above refrigerator is getting very hot
Check Thermostat.
Proper Cleaning/Defrosting of fridge and freezer.
Proper Placing and Distance from wall.
If your hand bear the body temperature of that specific area then its normal.
Contact technician to verify Freon pressure.
Best of Luck,
Regards:
Hassan
Side of frig is hot
Make sure the condenser fan underneath the unit where the compressor is is running. If that's not it check for ice buildup behind the back wall inside the freezer .(defrost problem)
Frig is hot only in upper front (divider) where two doors meet.
need to see if your fan is running in the freezer side if not replace it if it is then check to see if you have frost on the back lower wall inside the freezer if you have frost then you have a defrost problem
Hot
check to see if the fan at the compressor is running
Whirpool frig. freezer works frig doesn't
access to the evaporator fan is in the freezer behind the rear wall.
Frig not cold but freezer is ice maker not making much ice either
Is your fan blowing in the freezer? Frost on the back wall of the freezer usually indicates a defrost problem... defrost themostate, heaters, take back panel off and check evap for frost build up and if your fan in working.
Hotpoint HSS25GFT 25.0 Cu. Ft. Side-by-Side Refrigerator with GE SmartWater Filtration, LightTouch Logo
Top Hotpoint Refrigerators Experts
Dan Webster
Dan Webster
jdthefixer
Michael Thomas
Michael Thomas
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
