Dosent load pics to picasa
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Picasa or any other photo cataloging program.
SOURCE: problem in Olympus FE-170 Digital Camera
Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. In any case it could not make it worse Good luck!
SOURCE: broken Lcd panel
Broken LCD screen is quite easy to replace on the FE-170 and FE-210. I have purchased cameras with bad lens but good LCDs on ebay pretty cheaply( compared to having Olympus repair camera).
SOURCE: How do you transfer pictures from camera Olympus FE-20 to compute
one of the manual must help you.... if it does dont forget to rate!!! http://www.olympusamerica.com/files/autoUSB.pdf
http://www.olympusamerica.com/files/FE-360_X-875_C-570_FE-20_X-15_C-25_Instruction_Manual_EN.pdf
SOURCE: olympus fe-170 lcd display faints to bright white in seconds
you can replace the LCD screen for about 20 bucks.
SOURCE: no sound recording during video recording with olympus fe 170
The Olympus FE-170 does have audio capability, I have recorded many movies with sound using my Olympus FE-170...
But I am now having the same problem, all of a sudden, without any warning, audio ceased to work.
It really sucks, I took some great footage from a music festival, all soundless, what's the point?
Anybody actually got a solution for this; is there anything we can do to re-enable the audio capability for the Olympus FE-170?
