SOURCE: remote codes for a orion tv
i have 2 universal remaotes a rca and a zenith and i need the codes for an orion tv
SOURCE: Orion T. V. Codes
The manufacturer of the universal remotes make up the codes. Contact the maker of the remote or go to their website for the codes you need.
SOURCE: Need Universal Remote codes for Orion tv- One for All Remote
The TV codes for a URC-3021 and an Orion TV are:
0236, 0463
These are the steps to program your remote:
To setup your URC-3021 for a TV, these are the steps:
1. Turn on your TV.
2. On the remote control, press TV once.
3. Press and hold SET until the LED (red light) blinks twice,
then release SET.
4. Enter the first four-digit code for your device. If performed correctly,
the LED will blink twice. If the LED did not blink twice, repeat steps 2 through 4 and enter the same code again.
5.
Aim the remote control at the device and press POWER once. The device
should turn off. If it does not, repeat steps 2 through 5, trying each
code until you find one that works.
We would be happy to help you with getting your new DISH Network remote to control your TV. We're going to start by pressing and holding the TV button located on the top of your remote until all mode button back lights come on, and then release. Use the number buttons to enter the codes for your Orion TV; here are some of the codes we currently have for it: 720, 748, 748, and 748. Press the pound (#) button. To check that the code works try several different functions on the remote to make sure it will properly operate the TV. Remember that some codes may not be compatible with your equipment. If this is the case, try the other codes listed for your Orion TV until you find one that is compatible with it.
We hope this helps and thank you for being a valued DISH Network customer!
Phillip Chang
DISH Network Customer Service Representative
