1999 vauxhall astra, key fob not working so alarm goes off each time you open the car, attempted to change battery in the fob and reprogram the fob by inserting it in to the ignition and holding down both button for 30 seconds, friends recommendation, didn't make any difference, at the point now where I would rather just disconnect the alarm system as I'm confident no one would be that bothered about stealing the car but I have no idea how to disconnect. Any solutions to th eproblem or how to disconnect the alarm syatem would be greatly appreciated.
I am not 100% certain but resyncing the key fob won't necessarily affect the alarm which is likely to be integrated with the immobiliser - I think all it does is make the central locking work.
In addition to the key plip for the central locking, the key also contains a transponder chip that I believe is like a grain of rice and can be easily lost when taking the key apart to change the battery.
The transponder chip requires no power from the battery and is not connected to it in any way. It is programmed to the code of the immobiliser with dedicated equipment and is recognised when the key is inserted into the ignition.
Even if you manage to disconnect the alarm the embedded immobiliser is still likely to prevent the engine starting.
Vauxhall key fob re programming
and a few other links:
Cassini Spacecraft Dives Between Saturn and its Rings
SOURCE: vauxhall astra horn
The problem is in the loom in the steering wheel, it requires removal of the airbag and a new wheel loom to be fitted. The loom costs about £15.00 I think.
SOURCE: Vauxhall Astra estate, steering column defect.
the answer they gave u at the shop is true, there is no kit for that steering
sorry...
SOURCE: how to set the timing marks on vauxhall astra 1.4
put the dot on cam gears in between 2 dots on engine case. crank needs to be at TDC
SOURCE: I have a Y reg 1600 vauxhall astra estate with the
Pull each fuser out if the fuse box lid doesn't show a cig on the fuse lid and see if it's blown. Replace the blown fuse. If all the fuses look good trace the lighter back to the inline fuser and replace.
SOURCE: I have a Vauxhall Astra
i have a 2003 astra diesel and want to know if there is a drain plug on the fuel tank as i have put petrol in it
