Error message on Printer
SOURCE: Load MP Feeder
That is not an error message. it is telling you to load the Manual Paper feeder. Put some papaer in it and it will print. check youyr set up to make sure that you are printing to the trays not the manual feeder
SOURCE: want to print from letter
select the proper tray from the properties of printer. the properties could get by right clicking on printer icon.
SOURCE: Our printer says load MP feeder. We can't get it to print. Please
The front of the printer is a door that opens this is the MP feeder. Load paper in it and the unit should print. Someone likely sent a job requesting that tray.
for more help see.
http://www.lexmark.com/publications/pdfs/t640/eng/ug.pdf
Hope this helps
SOURCE: lexmark t642 load mp feeder with letter
The reason that your printer is asking you to load paper into the MPF is that it doesn't think it has that size paper in tray 1 or 2. Make sure that the green paper guide in the paper tray that you want to print from is latched in the correct position. This guide tells the printer what size paper is in the tray. If you have it even slightly out of position you'll get this message.
SOURCE: Hi I get this 250.07 paper jam check mp feeder on Lexmark t644
Defaulted the printer.
Check the cable form mp feeder connecto main board.
Check paper flag in placed the sensor.
Timming of mp feeder.
it hard happen to the maun board...
