The blue light that be on in the front of the computer will not come on, but the lights in the back of the towe are on, i have check all the cords and everything seems right, it will not even make a sound
Sounds like a power supply to me. Check on the back of the tower next to the power plug. Sometimes there is a red, slide-type circuit breaker. Switch it and see if your comp powers up.
The lights on the back of the tower are probably the network card. It usually lights up when its connected to a network or router, but is not an indication that the computer is running.
If you have a warranty, get the company to fix the problem. (this will be cheaper for you and less headache.) Also, opening the case may void the warranty.
If you dont have a warranty, I suggest taking it to a computer repair place if you're not the DIY type.
If you are the DIY type, research and purchase the correct replacement power supply. (This can be tricky, get help if you are not 100% sure)
If you have the wrong voltages, amperage, or cycles, you can fry everything on your computer!
Unplug all the cords, ground yourself, open the case, remove and replace the power supply, and try again.
problem with the pc
