Machine did an update - and now refuses to do anything when switched on,
SOURCE: I'm trying to program a
Hello
There is no setup codes for Blu-Ray players came out till now. Very sorry to say that, no universal of other remotes can be used with any brand of Blu-Ray playes, except their original ones. Likeways, no region hack codes also not available with Blu-Ray players, till now. I can't predict the future. I too looking for such codes. OK.
I had the same problem with my LG bd670
blu ray. I fixed it. It was a failed firmware update. I went to the
LG website and downloaded the update and copied it onto a flash
drive. I unplugged my blu ray (hdmi cable too), put the flash drive
into the usb port on front, and plugged in the power cord. It took a
couple of minutes but it loaded the update from the flash drive and
shut off. I plugged the in hdmi cable and turned on the blu ray and
done. All was well in the world again. I hope this helps anyone with
the "boot" error message on the LG bd670 blu ray player.
You can download any available ODD (Optical Disc Drive) updates from http://us.lgservice.com. Click Product Support, click Optical, choose your model number from the list, and click go. Click the Drivers & Software tab. Download the latest version posted (highest number).
The firmware for all recent drives works with Windows. Before running the update, make sure the drive is empty. Close as many programs running the background as you can. Run the downloaded executable file to start the update. Some will automatically start updating the dive and some will require you to push "Upgrade" or "Start". If the firmware doesn't see the drive it was designed for, it will not install.
WARNING: Never update the firmware if the problem you're having is the drive isn't seen by windows, won't write with the included software, or other interface related problems. Unless the firmware specifically states it fixes the problem you are having, firmware updates normally don't fix these types of problems. Trying to update the firmware when there are interface problems can damage the drive's firmware. An error when updating the firmware is usually caused by a problem with the drive interface or there is more than one drive connected to that IDE channel.
IMPORTANT: do not interfere with the drive during the firmware update. If an error occurs during the upgrade process, or the upgrade process is cancelled during this process, damage to the drive can occur. If you experience any problems or have any questions, please contact our LG customer support line toll-free at 1-800-243-0000.
Hope this helps you
