Question about Maytag Refrigerators
Water is dripping down back of freezer and then developes a frozen puddle in the bottom under metal wire bin. Eventually is gets down by the freezer and leaks water out of the bottom of the door. I have been breaking the slap of ice in the bottom every other day to prevent the water leaking out of the freezer door.
Refrigerator Repair Help Troubleshooting and Parts
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Posted on Jan 02, 2018
SOURCE: Icemaker issue: cubes melting at the bottom causing water leak out the front
J, sounds like your dispensor flapper is not closing properly and you are drawing warm air up into the ice bucket. This model had an issue where the flapper pin holder was part of the housing and would break off. They have a kit now that fixes that problem. The only other thing it could be would be low freezer temps or it's staying in defrost too long. With out being there, I would start with the dispensor flapper. Check it out and post back.. Catriver.
Posted on Apr 22, 2007
SOURCE: leaking fridge
Its probably the defrost circuit either the heater or the timer
Posted on Oct 30, 2007
SOURCE: Maytag side by side refridgerator
the drain tube is clogged or maybe frozen, remove the restriction and you will have no more problem
Posted on Apr 10, 2008
SOURCE: JCD2389DES Water Leak Problem
We also had this problem with a Jenn Air side by side. I cleaned out the drain tube and melted the ice in the collector tray but we still had water coming out of the freezer door later on. My wife started looking for a new fridge because she was tired of cleaning up the pudles daily. I went online to another site and found this to be a common problem. It seems the defrost cycle is not long enough to let all the water drain out of the collector tray and it ends up frozen in place and the the tube gets blocked and the the water runs down the inside back of the freezer untill it fills the the bottom of the freezer. Then it freezes and the the next time the water flows out the front of the door on to the floor. There are kits available to solve this problem and they cost about $20. I looked at what was in the kit and made my own part. It is a 9 or 10" long piece of # 12 or #14 copper wire (house wiring ground wire).
Turn off fridge and take the shelves out of freezer and then take off the large grill on the back wall and melt the ice in the bottom area where the metal water collector tray is. Look under the fidge where the evaporator tray is and make sure water is in fact running down the tube. To make sure it is, empty out the evap tray and put it back in and pour water into the defrost collector tray to see if the water flows down to the evap tray. If it doesn't then blow it out. If it does then take the copper wire and shove all but 2" of it down the tube that drains the collector tray. The last 2" or 3" of wire needs to be bent 90 degrees so that it lays flat in the tray. It seems the cooper wire that is down inside the tube conducts enough warmth from outside the freezer to keep the tray from freezing up to soon after the defrost cycle and lets all the water drain out down to the evaporating tray which is under the fridge. We never had water in the evaporating tray before because it was never making it down the tube. It has been many months now since my fix with no water on the floor.
Posted on Jul 10, 2008
SOURCE: Bottom of freezer has water dripping into it
We had a similar problem. It ended up being a frozen pea that fell down into the defrost drain and was blocking the water from draining out each time the freezer defrosted.
Posted on Aug 23, 2008
Jul 27, 2011 | Kenmore 18.3 cu. ft. Top Freezer...
Aug 16, 2010 | Kenmore Refrigerators
Dec 31, 2009 | Refrigerators
Sep 12, 2009 | Liebherr European Right Hinge Fully...
May 29, 2009 | GE Refrigerators
Jan 28, 2009 | Estate TT21AKXKQ / TT21AKXKT Top Freezer...
Nov 16, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Nov 15, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Jun 17, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
Apr 09, 2008 | Refrigerators
81 people viewed this question
I see many questions just like mine on this website fixya.com., however, I cant pull up the solutions (answers)for it. I am looking for soluition #3 that a member suggesed. How do I view the solutions?
Thx to solutions by 2 Boops and David Coomer I got on the right track. I used Pressurized air to blow out the blockage. Worked great. I was hesitant to use wire in case I caused further problems. Took no more than 15 minutes to take the back pieces out, clean out the tubing and put it all back together. Quick fix. Thx to both of you.
Obviously I found out how to find the solutions on this website.
