When i go to the menu to reset to factory settings the camera does not allow me to press on that bottom
SOURCE: Reset my camera settings
You can reset the camera to the factory default settings by pressing and holding down the two buttons on the top of the camera next to the shutter button. You will hear a short beep and then a long beep once the camera has been reset.
SOURCE: How do I factory reset
set camera mode to P, press Menu, right arrow over to card setup, down one to custom reset, right arrow to custom reset, press ok, yes to reset, ok
SOURCE: Need to factory reset E-Volt 500 Digital Olympus Camera
Put camera dial on P - go to Menu - camera 1 tab is highlighted - right arrow over to card setup - down arrow to custom reset setting - right arrow to reset and press ok - you will see reset yes or no - highlight yes and press ok - camera should now be in factory default settings
SOURCE: Master Reset Olympus x840
To reset the camera - have the camera in shooting mode - go to Menu - left arrow to reset - press ok - Highlight yes and press ok. This will set the camera back to factory default settings. Hopefully this should solve the issue.
SOURCE: i need a reset ...
Do a manual reset: remove the card and battery...press all the buttons...leave it alone for 20 minutes...insert the card and then the battery...turn it on. However, this blue picture problem doesn't sound like a reset will fix it.
Testimonial: "ey ... well, i took my cam to the store.. and the man did excact what u said ... and it worked... so ehm .. u were right ;P "
