A
Anonymous Posted on Jan 15, 2018
Jensen cassettemate converter is connected to pc but icon is crossed saying connect usb
Have downloaded software, placed cassette in converter, software loads but the usb which is pluggedinto the pc keeps saying its not connected. Tape runs but no recognition on screeen of activity. Casssette plays with usb plugged in so there is power but its not recognising it in cassettemate screen.
Eric Sutherland
Level 3:
Master:
  • Master 665 Answers
  • Posted on Jan 15, 2018
Eric Sutherland
Master
Level 3:
Master:
Answers
665
Questions
0
Helped
263216
Points
2023
Faulty USB cable or socket.
5 Related Answers
Anonymous
  • 19 Answers
  • Posted on May 02, 2007
SOURCE: ipod nano
switch the hold button on and off, then hold horizontally, and push the menu button and center button at the same time. hold them down untill the ipod restarts and the apple logo apears. If that doesen't work, plug into the newest itunes program, and push restore.
Anonymous
  • 55 Answers
  • Posted on Nov 25, 2007
SOURCE: Recognition of plug-in
try to manage it with the software which came with your cam
Anonymous
  • Posted on Jan 25, 2008
SOURCE: IRIVER PLUS 3 MEDIA TRANSFER SCREEN
My understanding, as a new user, is that IRiver plus 3 only communicates with the player via UMS mode, which is not the default. Windows Explorer and Windows Media Player only communicate through MTP mode. If you change from MTP (the default) to UMS, it will reformat the player and delete all your files.
In other words, do not use iriver plus 3 unless that is the only software that you want to use. Boing back to MTP mode after a sync or download will then delete all THOSE files you just downloaded.
I just say NO to Plus 3.
Good luck.
Anonymous
  • 3 Answers
  • Posted on Jan 31, 2008
SOURCE: archos 605 usb connection problem
its possible you could have picked up a virus that is making unauthorized changes to your pc. happened to me. had to reboot pc to original factory settings.
ThaMp3Doctor
ThaMp3Doctor
  • 8597 Answers
  • Posted on Jul 06, 2008
SOURCE: SONY NW-A3000
Bad news - if you tried multiple pc's and it still failed, then your player is done.
Make sure you:
reset the player
upgraded the firmware
used the recovery tool
called Sony to be sure
last ditch effort:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware.
Wizard.
Buh-bye!
-Tha Mp3 Doctor
HOW DO I GET SOFTWARE FOR JENSEN JSCR50 CASSETTE USB
Either by purchasing a new unit from Amazon.com as linked below or by .zip file download from the attached links. Jensen Cassette Tape to MP3 Converter Free Download Streaming Internet...
Ion ez audio converter
Check to see if the software requires "NET Framework 1.1"
If it does it will NOT work on a Windows 8.1 machine, only Windows 7.
Instruction Manual for model 2034
there is no manual,
Tape-2-MP3 Converter/Player
Convert your cassette tapes to Audio CD or MP3 files with 3 simple steps! Connect portable cassette player/converter to PC or Mac via USB cable. Transfer by Installing provided software and simply press "RECORD" while playing the tape. Create MP3 files from transferred audio to burn to CD or import to iTunes for use on your iPod device.
USB-to-Computer Recording
Convert from cassette to digital formats directly to your PC or Mac computer via USB cable and simple Audicity® software, both included.
1helpful
Cassette mate
The product arrived with an instruction manual. I followed the instructions, installed the included software, and then was unable to get the product to work as my PC (Windows 7) did not seem to recognize the device. I tried several USB ports to no avail. I emailed the seller and promptly received an email with different instructions. Although the software version on the installation CD was different from that referenced in the instructions, I was able to install and finally got the device to work as needed. The problem is that there are two programs on the installation CD and one (cassettemate) appears not to function, while the other (audacity) is what is needed. This is not indicated in the instructions that come with the device.Close cassette mate window and open audacity press play in the cassette player and press recording button in audacity program.
1helpful
Cassette mate I cannot get rid of the red x on the cassette in the taskbar, so cannot copyto vista computer
the product arrived with an instruction manual. I followed the instructions, installed the included software, and then was unable to get the product to work as my PC (Windows 7) did not seem to recognize the device. I tried several USB ports to no avail. I emailed the seller and promptly received an email with different instructions. Although the software version on the installation CD was different from that referenced in the instructions, I was able to install and finally got the device to work as needed. The problem is that there are two programs on the installation CD and one (cassettemate) appears not to function, while the other (audacity) is what is needed. This is not indicated in the instructions that come with the device.
How do i download music on my jensen mp3 player
MP3 players can only play music files in mp3 file format. You can download mp3 music files from the Internet to your computer and then copy them to your MP3 player using the USB cable. For your CD collection, you need to convert your CDs to mp3 music files onto your computer or download them from the Internet and then copy them to your MP3 player after you have connected the USB cable to the MP3 player and the computer.
You can do this using Windows Media player and Rip the CDs - Media Player will create a MP3 music file for each music track. Click on this link for instruction on converting music files to mp3 file format :- http://www.fixya.com/support/r5798418-creating_transferring_mp3_music_files
2helpful
How do I connect a Stanton T80 turntable to my PC?
First of all you can try with the line input of your Pc audio card. There will be 3.5 mm stereo socket in the pc audio card (blue color ) which will marked as LINE IN. To connect the turntable to this socket you need a RCA to 3.5mm Stereo converter like on in the picture bellow. I have also added a link to a video which will help you to do the same. In the video the are showing a cassette deck. In you case Turntable in place of cassette deck.
You have to set the switch on the back of your Turntable to LINE OUT. Then you can use any software to record the signals from the LINE INPUT of your PC.
If you need a high quality recording the you have to use a special converter which will do the job neatly.
To convert or upload (copy) tracks in LP in good quality then you need a interface unit between the Turntable an PC. Which will convert the analog audio out to Digital signal ( RCA to USB). The unit will come with the driver for it. That you have to install on your PC.
Keep on thing in Mind that when your are using such a converter between Turntable and PC you have to set the switch on the back of your Turntable to LINEOUT.
Here i have added link which will lead you to such a USB converter. Which will provide you studio quality stereo.
Manual for Stanton T80
Video
RCA TO USB converter
3.5mm STEREO to RCA converter cable.
Ajin
I can not get the media manager for it to bring up music. Also, should I download a WMA for it to convert. Mine says on the packaging to download the Coby Media Manager but it came with no software. Not...
Coby Media Manager is embedded on the MP3 player. When the MP3 player is connected to your PC, that is all it will say is 'USB Connected'. To access the coby media manager, go to Start > Computer > It will be a 'Removable Disk' drive, double click it, inside of there will be a coby-mediamanager.exe file, this is the software, double click it to install it. It will put an ICON on your desktop, this software is what you use to sync music, photo or video to your MP3 player. If you need the Coby Media Manager - you can downlod from here: http://www.cobyusa.com/files/software/MP707_Media_Manager.zip
2answers
Top Jensen Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Ngoro
Are you a Jensen Audio Player and Recorder Expert? Answer questions, earn points and help others
