Question about Acer Televison & Video
Acer flat lcd 26' al2871w support
I have to keep tuning the channels each time I turn it off
2 Related Answers
upallhours36
  • 36 Answers
SOURCE: my acer lcd will not keep the channels ihave to
you seem not to have saved them in the first place.
power down then unplu tv and signal imput.then plug back up .then make sure you SAVE channels
Posted on Nov 03, 2009
ladywinn
ladywinn
  • 5138 Answers
SOURCE: My Warfdale 19" LCD TV
Problem will be either bad capacitors that are vented or puffed up on Top or you need to replace the main board the one you connect cable to Encompass Parts Distrbution might have it on stock
1-800-638-3328
Posted on Aug 23, 2010
KDL-40V3000 program not tuning
if possable retune with a known working connection ie at the house next door
this will rule out your own setup and may save you time / money in the long run
May 15, 2012 | Sony BRAVIA KDL-40V3000 Television
Can i get it to start on channel 1 and not channel 9
You should be able to. It sounds like your radio is hooked up in a manner that disconnects it from ALL the power once the ignition is turned off. This causes the radio to return to channel 9 by default program when powered on again.
Try connecting the radio hotwire to the fusebox at the factory am/fm radio fuse junction (be sure the amps for the cb + the am/fm don't exceed the rating for the fuse). This should keep power supplied to the radio even with the engine off, and it should remain tuned to channel one every time you turn it on.
Oct 15, 2009 | Midland 77-099 CB Radio
Same problem
At lunch time today all freeview boxes have to re-tuned so you will get channel 5 and ready for HDTV.
Some old boxes according to sources are packing up altogether so you have to keep this in mind.
You can re-tune your freeview box using your OSD (on-screen display) and locate re-tune.
If you are unsure how to re-tune the box which many people are having problems with please visit this website for a guide for your model box >>>>
http://www.tvretune.co.uk/
http://www.tvretune.co.uk/productmanuals/
Regards.
Sep 30, 2009 | Philips Televison & Video
Vizio 32lcd turns itself off on certain station
Do a full channel scan again. It should solve that problem.
Jun 14, 2009 | Vizio VW32L 32 in. LCD HDTV
Cant retune my digtal freeview as my picture keeps freezing
The retuning process is as follows:
  1. Press the [i+] or MENU button on the remote control to display the DIGITAL INFO menu.
  2. Press the BLUE button to display the MAIN MENU.
  3. Press the UP or DOWN buttons to highlight AUTO TUNING then press the OK button to display the AUTO TUNING MENU.
  4. Press the RED button to start the auto tuning process for all available digital channels.
  5. Wait for the process to complete.
If you wish to CANCEL the auto tuning process whilst it is processing then press the BLUE button at any time.
You may lose some channels when you retune the TV as the channels have been rearranged. To locate them look at the EPG although you may still find that some channels are no longer available on FREEVIEW. See the following link for additional information
http://www.freeview.co.uk/_retuneinfo/
If the above process does not work then check the link above for additional information and also visit the accompanying site links below to find more information for your model of TV / FREEVIEW box.
For troubleshooting the retune procedure visit http://tvretune.co.uk/troubleshooting/
For specific model information visit http://tvretune.co.uk/productmanuals/
Jun 02, 2009 | Samsung HL-S5086W 50" HDTV
Cannot get local channels back after dropping cable.
Are you positive that your city has not done the Digital Conversion? Some Cities are doing it early before the February deadline. Also make sure you are tuning in to the correct channels. Meaning that if on your Cable Provider ABC was on Channel 3 that does not mean that ABC with still be on Channel 3 after you have your Cable turned off. Most of the Time the Local Stations Tag will let you know what channel its on. It will be something like "KWAS ABC 27" So on your TV you would Tune it to channel 27 to get ABC and the same fore NBC , FOX, CBS , etc...
I hope this helps Take Care =)
Dec 07, 2008 | Televison & Video
Auto tune
unfortunately tramission has been changed and certain boxes have an auto tune process as a loop. the box will work but you will have to deselect it everytime from time to time. i have the same problem with the same model. idt59g i believe. its down to the local argos with another 20 pounds to get a newer one im afraid.
i did try to turn off the auto tune option but have had no luck
Jul 09, 2008 | Sagem PVR 6280 Freeview DTV Receiver /...
Tv problems
I am assuming that you are using cable and not an aerial/antenna.
On your concern "...channels do not tune...correct channel numbers...", it is possible that when you re-tuned the TV your setting was set to AIR or STD, try to re-tune again but this time pls verify that you are in CABLE mode. If on the other hand you are using aerial/antenna, then it is the other way around.
Channel 0 would automatically be your Audio/Video (which is where your DVD/VCR is connected). If you re-tune, chances are that Channel 0 ) would be back. To be on the safe side, pls power on likewise the DVD/VCR.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Mar 04, 2008 | Konka K1938U 19" TV
Televison & Video Logo
26 people viewed this question
Top Acer Televison & Video Experts
Marvin
Marvin
Paul Bade
Harrie
Are you an Acer Televison and Video Expert? Answer questions, earn points and help others
