Question about Champion International Champion Power Equipment 46515 3500 Watt 196cc OHV 4cycle Gas Powered Rv
How to set the over head valve timing on a 196cc ohv cpe champion engine
Model #46514
Posted by STANLEY FARLER on
1 Related Answer
Carl Robinson
  • 33 Answers
SOURCE: builds up pressure pop off valve at tank opens will not regulate pressure
I would say you have a problem with your pressure switch, you may need to adjust it down. The pressure switch is normally located under plastic cover where your on off switch is on the compressor. There should be a screw with arrows next to it. Try that, otherwise you may need a new switch
Posted on Oct 01, 2012
11.5 Briggs Straton Poulan riding mower, location of MFG serial number
Depending on which your needing. The body model and serial decal is usually located either on seat or on the body under seat.
If it is the engine it depend if OHV or a L-head engine. OHV serial (date code) is on the valve cover. L-head is located somewhere on the engine's flywheel shroud.
Mar 11, 2015 | Poulan Garden
Only runs with choke
There is an air leak in the seals somewhere between the carb and the intake manifold. You are getting too much air! ALL of those seals need to be changed, As the paper seals age they develop small cracks that kill the vacuum made by the engine to pull in the gas/air mixture!
Dec 23, 2012 | Champion International Champion Power...
Low current. Will hardly drive a sander or lights. Voltage guages says 120V. Unit is 3 years old but has maybe 10 hours of use max
I found this at http://www.championpowerequipment.com/tech-bulletins/
AVR Voltage Adjustment
This bulletin covers the following Champion Power Equipment models:
C46535 C41150 C41365
C46540 C41155 C75520E
C49055 C41255 C71350E
Note: Read instructions completely before performing service.
1. On the end of the generator locate the round yellow cover held on by two 7mm bolts.
Remove the two bolts and the yellow cover will come right off.
2. At approximately 7 o'clock you'll see a kidney shaped electrical component called the AVR,
which is held on by two 7mm bolts. Remove the two bolts but do not disconnect the wiring
and turn the AVR over so you can see the backside. You should see a round part coming off
the AVR, this is the capacitor. You should also see a small rectangular box with a jewelers
screw, this is your voltage adjustment screw.
3. With a flat head screw driver turn the jewelers screw counter clockwise and this will lower
the voltage. As the screw is turned back watch the volt meter to see adjustment, the
generator must be running to do this.
4. Adjust the screw until the meter reads 250 volts. On model C46540 when the toggle switch
is turned to the 120 side the volt meter should read around 130 volts. Optimum voltage is
121.8 volts.
5. If voltage does not decrease or does not hold a steady output please contact Champion at
877-338-0999 for a new AVR.
If you have any questions, please contact Champion Power Equipment:
Champion Power Equipment, Inc.
10006 Santa Fe Springs Rd.
Santa Fe Springs, CA 90670
Phone: 1-877-338-0999
Email:
[email protected]
Jul 02, 2011 | Champion International Champion Power...
My Champion 6.5HP Generator has a gas leak under the gas tank. The gas shut off valve is missing a rivet (one of two). I've got it unscrewed but am not sure how to get a replacement part. I have the...
They have a website at http://www.championpowerequipment.com. Click "support" and they tell you "If you need to order a part please call our tech support line. Our professionally trained technicians will be able to assist with placing orders. Orders ship within 1 business day - orders received before 2:00 PM (PST) will be shipped same day." The number is 1-877-338-0999. They also have many service bulletins thee thay will help solve many problems.
Apr 23, 2011 | Champion International Champion Power...
Champion generater. It seems fuel pump is not pumping the gas . what to do?
First start small Check to see if there is any clogs in the line also check the fuel filter if the pump is broken go to google and type the model number in and that should bring up everything about that and possibly help you find parts for it
Mar 10, 2011 | Champion International CPE 1000Watt...
Can i put a ohc in my exploere or do i have to stay with the ohv what is the dif
You would have to change engine, OHC-over head cam is the cam sets on top of the cylinder head, OHV-over head valve the cam sets in the center of the engine using pushrods to open/close the valves.
Feb 20, 2011 | 1998 Ford Explorer
The coil rope broke I would like to know how i can repair it. Generator 5500 watt champion.
If I understand correctly, you have a pull-start generator.
The rope to the pull-start broke.
This happened to us out on the job one day.
Our equipment might be different than yours. Our pull-start assembly is held with 4 bolts. Simply remover those bolts and lift off the cover ... carefully. The rope is attached to something I will call a pulley. The rope wraps around the pulley several times.
Do not lift out the pulley that the rope attaches to >> or the spring that re-winds the rope will come un-sprung (at least it did on our machine). If the spring comes unwound, then you got another job, and have to put the spring back also. Your machine might be different.
Keep pulley in place. Remove rope. Get another rope with same diameter and length and put it in.
Oct 18, 2010 | Champion International Champion Power...
Need a spark plug size for a yardpro self propelled lawn mower model number yp6y22cha briggs and stratton 6hp
If your mower does not have "OHV", overhead valves. You can use a Champion j19lm spark plug.
If you discover you do have overhead valves; A Champion RC12YC, will work.
Apr 28, 2009 | Mtd 22" Yard Machine Push Mower
Champion International Champion Power Equipment 46515 3500 Watt 196cc OHV 4cycle Gas Powered Rv Logo
581 people viewed this question
Top Champion International Electrical Supplies Experts
Gene Haynes
Marvin
Marvin
Are you a Champion International Electrical Supply Expert? Answer questions, earn points and help others
