Toshiba big screen tv wont quit streeming menu options
Posted by nate lee on
SD Tech
    Top Expert:
  • 14,553 Answers
A model number would assist me in helping but here is a possible reason/s:
If menu keeps popping up may be a defective menu button on the set.
If set is actually going thru a "Demo" mode showing all features that demo has been turned on and needs to be shut off---usually in most sets it is somewhere in the setup or options menu.
Posted on Mar 20, 2012
How do I access advanced menu options so I can adjust overscan settings?
get to the on screen tv menu and look for aspect ratio change that ,save and exit
May 18, 2015 | Toshiba 32ZH46P
How do i unlock the key--- display on my Provision television that is operated by a beko 12.1 remote control.I also need the service code for some Geometric adjustment.
Service Menu Access Procedure To access the service menu, press and hold the handset sound mute button whilst pressing the TV's front panel 'Menu' button (under the front panel cover on the TV). The up/down channel buttons on the handset step through the options and the left/right buttons change the data values. Turn the TV off to get out of service mode and DO NOT touch any other handset buttons whilst in service mode. Service menu access is also similar for many other Toshiba large-screen TV's so this procedure may work on other Toshiba TV's - even those sold outside the UK.
Maybe this list can help you, click here for a list of each widescreen Toshiba TV Service Menu adjustment with details on the purpose of each.
The factory settings of each service menu option will be entirely different on every TV manufactured, due to component, tube and scan coil tolerances, so don't under any circumstances adjust your TV's settings to my factory default settings or your TV's picture will probably look awful! The factory settings are provided out of interest - the useful part of this document is actually the definition of each service menu option. You will see that some geometry settings are duplicated for each screen mode such as 'Cinema' and 'Subtitle'. This could, for example, help resolve a geometry problem that's present just in one screen mode.
I hope help you with this.
Oct 14, 2009 | Televison & Video
36A43 Toshiba picture size
Change the Yoke got short circuit spires
Aug 20, 2009 | Zenith A25A23W 25" TV
Menu Screen turns on/off on its own...alsoTv video flips through
The front panel Tactile Switches need to be replaced. Replace them all. This should be the part #. 23344507. You can order it through Encompass Elect. 800-638-3328.
Hope this helps,
Skyassoc
Jul 01, 2009 | Toshiba 32AF43 32" TV
The tv seems really dark.57in theatrewide hd toshiba
Go into the tv menu and select the Preferences menu and set your picutre preference from Theater to Normal. The TV is currently in Theater mode, wich is for viewing with no lights on in the room. Switching it to normal lightens the pictue a lot.
May 27, 2009 | Toshiba 57H81 57" Rear Projection...
My son was messing with the buttons on my big screen and now theres a big black box in the middle of the screen.. when i turn up the volume it goes away but when you dont press any buttons it goes back..
well u have that there because... he massed up the menu like in those tv's there is a option if u wana do 2 things at one time like watch the tv and play video game so basicly there is nothing wrong with thee tv.. u have to go through the menu to shut the second screen off.. its probbaly for video 1 or video 2..!! just go through the menu one more time and go on every option u can and u might find it..where it says u wana turn the video screen off
Jan 15, 2009 | Mitsubishi VS-60607 TV
Brightness on my tv quit workin
open your tv.At the back you see a plyback,it is big parts of tv with a wire attached to the picture tube,that is plyback At the buttom you wiil see a two knob, the lower knob is for the screen and the upper knob is for the focus.Adjust the lower knob or screen .
Nov 16, 2008 | Toshiba 36A42 36" TV
Menu is on screen and tv wont do anything
try a hard reset first - unplug tv from power source and all cables for about 1 hour, reconnect everything and see..
Oct 26, 2008 | Toshiba 36A43 36" TV
Televison & Video Logo
53 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
