I haven't used it in a while (6months) and now I notice that it wont autofocus. the image on the LCD is blurry and only looks at all focussed when pointed at very close subjects. when I try and zoom, it doesn't enlarge/decrease the image until it gets to the macro range, then it's just an enlargement of the blurry image The camera is fully charged, I have tried all the image, focus, photo and video options, all with the same results. Is there some type of firmware I can update? Any help or advice would be greatly appreciated!
SOURCE: Sanyo XACTI HD1 Camera-No Pictures / Videos captured.
I have intermittent problems of this type too. Occasionally I get a blank screen in the display mode.
Does the red light on the back of your camera flash while the screen is dark? Mine does.
It is beginning to bug me a lot. It may be because I got my camera wet in the past (and hence I have broken my camera), but I doubt that would result in a partial failure.
I think that the Xacti HD1/HD2 has issues a bit like a blue screen of death on an old Windows computer when faced with storage problems.
I.e. it works but crashes sometimes when it cannot store to its storage medium.
These things work for me
1) Turning the power on and off via the button underneath the screen.
2) Removing and re-inserting the SD card.
3) Turning the power on and off by removing the battery.
4) Using a different (and faster?) SD card.
I am still using my HD2, but I am finding that I must attempt solutions 1-3 about once a day.
It could be because the card I have been using recently is not fast enough. The HD2 accepts both SD and SDHC cards. My SDHC card (which is newer) seems to result in fewer problems, either because the SDHC format is more suited to the Xacti HD2 or becaues the SDHC card I have is faster that then SD card I have. I suspect problems with the speed of the card. I am using cheap SD cards.
SOURCE: Can't download my video files from xacti e2 to my computer
TRANSFERRING RECORDED IMAGES AND VIDEOS FROM YOUR VPCT700 DIGITAL CAMERA TO YOUR COMPUTER
Connecting the Camera to Your Computer
1. Connect one end of the USB cable to the PC/AV terminal of the camera.
2. Connect the other end of the USB cable to an available USB port on your computer.
3. Turn on your camera.
-The [USB] screen appears.
4. Select [PC] with the Up and Down Arrow buttons, and press the SET button.
5. From the Windows desktop, double click on “My Computer”.
6. Look for a new “Removable disk” icon. This “Removable disk” is actually the memory card in your camera. Typically, the camera will be assigned drive letter “E” or higher.
7. Double click on the removable disk and locate the DCIM folder.
8. Double click on the DCIM folder to open it to find more folders.
-Your recorded images and video clips will be inside these folders.
-Copy & Paste or Drag-N-Drop image and video files to a folder on your computer.
Mac users: Double-click the “untitled” or “unlabeled” disk drive icon on our desktop. iPhoto may automatically launch.
Downloading images and Video Files
When the camera is turned on and connected to your computer, it is considered to be a disk drive, just like a floppy disk or CD. You can download (transfer) images by copying them from the “Removable disk” (“untitled” or “unlabeled” disk on a Macintosh) to your computer hard drive.
Windows
Open the “removable disk” and subsequent folders by double clicking on them. Your images are inside these folder(s). Select the images that you want, and then choose “Copy” from the “Edit” menu. Open the destination location (folder) and choose “Paste” from the “Edit” menu. You may also drag and drop image files from the camera to a desired location.
Macintosh
Open the “untitled” disk icon, and the destination location on your hard disk. Drag and drop from the camera to the desired destination.
NOTE
- Memory card users may prefer to use a memory card reader (highly Recommended).
- Video playback application is not included with the package. Make sure that video playback application has been installed in your computer.
SOURCE: Lcd on Video camera not working
take the LCD apart & look up the numbers on the back of it, order the part from were ever you find it form google & put the new one in urself when it arives, this will safe you @ least 100$ on someone else doing the same thing
SOURCE: Sanyo Xacti camera and 4 Gb SD card
Friend is it possible that u r card is corrupted so plz contact the shop where bay this and return it .. and take a new one replaced by it
SOURCE: blurry enlargements
I suggest altering the settings a little and if that doesn't work try using a different software to enlarge images.
Such as windows photo gallery. That's not too good for enlarging just good for keeping the quality up if that isn't good enough try using a free trial of photo shop.
Hope I helped Dr Red
